X-Firefox 14.0.1 [rev6] flash portable plugin bugs. thanks. |
dlusera |
Registered Member #39104 Joined: Fri 09 Jul 2010 - 12:38Posts: 37 | start on 11.3 version flash plugin freeze some flash website, such yahoo mail. i already do many test, only found on 11.3 and later version. 11.2 and below is ok. I not install flash just copy the flash dll on xfirefox\Lib\Mozilla\Plugins. this only freeze on windows 7. only set the windows xp compatible mode is works. hope check with detail and fix. many thanks. | ||
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | Obviously you have chosen the wrong way for the usage of the Adobe Flash Player in conjunction with the browser X-Firefox. It's not correct to copy the appropriate file *.dll in the folder X-Firefox\Lib\Mozilla\Plugins. Instead you must install the Adobe Flash Player on your Windows OS. In a first step you should uninstall a previous (older) version of the Flash Player, which is installed on your PC. For that purpose download the uninstaller. Afterwards exit your browser X-Firefox and follow the instructions under No.3. In a last step restart your computer. Now you can download the Adobe Flash Player 11.4.402.265. Again close your browser X-Firefox and run now the installer of the Flash Player. I hope that these instructions help you. [ Edited Fri 24 Aug 2012 - 14:24 ] | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | @Dropper: the dlusera's procedure it is OK! the real problem is on 11.3 version flash plugin. This issue (freezing) is remarked very often also on installed Firefox. so, info for both: keep the old one 11.2 dll in "\Lib\Mozilla\Plugins" or use the new 11.4 dll and be happy!! (since 11.4 Adobe has solved this issue.) [ Edited Fri 24 Aug 2012 - 15:30 ] | ||
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | I use X-Firefox 14.0.1 in conjunction with the winPenPack menu. If I understand you correctly, then I can copy the file "NPSWF32_11_4_402_265.dll" from the folder C:\Windows\system32\Macromed\Flash (I use the OS Windows XP SP3) and paste it in the folder D:\wpp_full_4.0-beta2\winpenpack\Lib\Mozilla\Plugins (that's the special path on my PC). Afterwards I can uninstall the Flash Player from PC. Still, I could use the Adobe Flash Player with X-Firefox browser. Is that right? But I found a lot of other files in the folder C:\Windows\system32\Macromed\Flash. Is it enough anyway, that I just copy and paste the file "NPSWF32_11_4_402_265.dll" as described above? | ||
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | I have searched for the cause, why Flash-based video content bring Firefox to freeze. In the Firefox support I found now a possible solution for that problem. Indeed the failure occurs only in conjunction with Flash 11.3. Here now the workaround for Flash 11.3.
Another possibility would be to use the new Flash 11.4. | ||
dlusera |
Registered Member #39104 Joined: Fri 09 Jul 2010 - 12:38Posts: 37 | I already tested new flash. also has a sone problems. login on winpenpack.com also freeze. I test, just 2 method is normal. 1.disable java script. 2.diable flash or use flash 11.2 or below version. 3. set compatible on windows XP mode only. I test 2 computer with new x-firefox, on windows 7 64bit has a some problems. I don't why. hope help. | ||
