Installation of Java Runtime Environment (JRE) 7 Update 10 impossible |
| dropper |
![]() ![]() Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | I tried to install the JRE 7 Update 10. After I run X-RssOwl, I got the error message, that it's not possible to install Java. Then I've started X-LibreOffice and it seemed, as if Java was updated. Finally I looked in the installed Plugins into X-Firefox, but there will displayed again the old version JRE 7 Update 9. Consequently is really the update failed. | ||
| dropper |
![]() ![]() Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | About the website "Test whether Java is working on my computer" I can now confirm, that I use the actual Java version with X-Firefox (JRE 7 Update 10). Nevertheless in my Addon Manager of X-Firefox will displayed the outdated version JRE 7 Update 9. Kind of odd!!! | ||
| Taf |
![]() ![]() ![]() Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3376 ![]() | Thanks for Your feedback, dropper. we'll try to investigate on this strange behaviour | ||
