![]() Go to page << >> |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Calibre 0.9.27 Link winPenPack Aggiornamento dalla versione 0.9.26 alla 0.9.27 Home: -Link- ![]() Direct link: -Link- ![]() | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Calibre 0.9.28 Link winPenPack Aggiornamento dalla versione 0.9.27 alla 0.9.28 Home: -Link- ![]() Direct link: -Link- ![]() | ||
Bourne |
![]() ![]() ![]() Registered Member #4287 Joined: Fri 20 Apr 2007 - 16:55Posts: 571 ![]() | Ho testato l'ultima versione nuova di pacca, la 0.9.29, con l'attuale x-launcher: sembra essere tutto OK. Ho provato sulla versione 64bit con installer msi (su questa versione sono riuscito ad estrarlo con il solito uniextractor), su Win764bit e account standard. | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Calibre 0.9.30 Link winPenPack Aggiornamento dalla versione 0.9.29 alla 0.9.30 Home: -Link- ![]() Direct link: -Link- ![]() | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Calibre 0.9.31 Link winPenPack Aggiornamento dalla versione 0.9.30 alla 0.9.31 Home: -Link- ![]() Direct link: -Link- ![]() | ||
Bourne |
![]() ![]() ![]() Registered Member #4287 Joined: Fri 20 Apr 2007 - 16:55Posts: 571 ![]() | tutto ok con l'attuale launcher | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Calibre 0.9.32 Link winPenPack Aggiornamento dalla versione 0.9.31 alla 0.9.32 Home: -Link- ![]() Direct link: -Link- ![]() | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Calibre 0.9.33 Link winPenPack Aggiornamento dalla versione 0.9.32 alla 0.9.33 Home: -Link- ![]() Direct link: -Link- ![]() | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Calibre 0.9.34 Link winPenPack Aggiornamento dalla versione 0.9.33 alla 0.9.34 Home: -Link- ![]() Direct link: -Link- ![]() --- edit zandet2 --- software wpp aggiornato [ Edited Mon 10 Jun 2013 - 22:52 ] | ||
Bourne |
![]() ![]() ![]() Registered Member #4287 Joined: Fri 20 Apr 2007 - 16:55Posts: 571 ![]() | Scusate, ma la versione in download è ancora ferma alla X-Calibre 0.9.18 [rev1], quando intendete aggiornare (io ho dato dei feedback ehh)? | ||
