Activation of protocols works not for X-Firefox |
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | I have installed X-Firefox in the winPenPack Net menu (winPenPack Launcher Version: 2.8.67.2350). In the configuration menu I have highlighted X-Firefox. Then I clicked on the key F5. In the now appearing dialog window "Properties" I have chosen the tab "Protocols". In the tab "Protocols" I activated the check mark next to "Http/Https". After starting of my standard email client (Microsoft Outlook 2007) I received an error message when I have clicked on a link within an email. Here is the content of this error message: "Firefox" e gia in esecuzione How can I open a link successfully? | ||
LordJim60 |
Registered Member #33962 Joined: Sat 18 Jul 2009 - 08:45Location: Roma Posts: 1147 | If you try to use another browser ( i.e. X-Iron ) do you have the same result? | ||
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | As recommended I've installed the browser X-Iron. With this browser I can easily open multiple links. With X-Firefox I can only open a link when X-Firefox is not running (see the above error message). Accordingly it's also impossible to open more than one link at the same time. This behavior seems to be a bug in X-Firefox. [ Edited Sun 07 Apr 2013 - 22:10 ] | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | Hi dropper, I solved this issue with a modification in "x-firefox.ini" in "OPTIONS" section try changing:
MultipleIstances=false
in
MultipleIstances=true
Anyway, be careful with this modification in you have also a LEGACY INSTALLED version of firefox in the same PC. The risk is: when you close X-Firefox, if existing a LEGACY profile folder (located in% AppData%), all these data could be irreversibly deleted! Our suggestion is to activate this option only if you are sure that the computer on which you use X-Firefox is NOT hosting an existing installation of Firefox | ||
