Aggiornamento: X-QupZilla Go to page >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-QupZilla 1.40 Link winPenPack Aggiornamento dalla versione 1.35 alla 1.40 Home: -Link- Direct link: -Link- ---edit by Taf--- sistemato il link alla scheda DL di wpp testato con vecchio launcher: nessun problema, ma le cartelle del programma portable nativo sono diverse, meglio verificare [ Edited Tue 12 Mar 2013 - 14:24 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-QupZilla 1.4.1 Link winPenPack Aggiornamento dalla versione 1.4.0 alla 1.4.1 Home: -Link- Direct link: -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Mon 22 Apr 2013 - 17:57 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-QupZilla 1.4.2 Link winPenPack Aggiornamento dalla versione 1.4.1 alla 1.4.2 Home: -Link- Direct link: -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Tue 30 Apr 2013 - 00:07 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-QupZilla 1.4.3 Link winPenPack Aggiornamento dalla versione 1.4.2 alla 1.4.3 Home: -Link- Direct link: -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Sun 26 May 2013 - 17:16 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-QupZilla 1.4.4 Link winPenPack Aggiornamento dalla versione 1.4.3 alla 1.4.4 Home: -Link- Direct link: -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Wed 11 Sep 2013 - 17:42 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-QupZilla 1.6.0 Link winPenPack Aggiornamento dalla versione 1.4.4 alla 1.6.0 Home: -Link- Direct link: -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Fri 03 Jan 2014 - 14:53 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-QupZilla 1.6.1 Link winPenPack Aggiornamento dalla versione 1.6.0 alla 1.6.1 Home: -Link- Direct link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-QupZilla 1.6.3 Link winPenPack Aggiornamento dalla versione 1.6.1 alla 1.6.3 Home: -Link- Direct link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-QupZilla 1.6.4 Link winPenPack Aggiornamento dalla versione 1.6.3 alla 1.6.4 Home: -Link- Direct link: -Link- [ Edited Mon 14 Apr 2014 - 14:35 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-QupZilla 1.6.5 Link winPenPack Aggiornamento dalla versione 1.6.4 alla 1.6.5 Home: -Link- Direct link: -Link- | ||
