[Released] X-Lastar 1.3.1_rev1 |
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Nome del software: LASTAR Direct Link al download: -Link- ![]() Dimensione File: 9.2 Mb Nome autore: Arnaud Champenois Sito Web Autore: -Link- ![]() Descrizione: Software per la normalizzazione e la divisione di file audio / LASTAR is a batch (non-interactive) audio processor for loudness adjustment and file splitting of a batch of audio recordings, using audio transparent maximizer. At the opposite of usual available softwares, loudness normalization is done on signal power, which leads to a louder and more homogeneous result than a usual "peak" normalization, in particular on live recordings Lingua: Sistema Operativo: Windows XP 32 bits and above Versione: 1.3.1 Licenza: GNU General Public License version 3 Screenshots: ![]() P.s: Posto in questa sezione per errore test portabilità [ Edited Mon 27 May 2013 - 22:18 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | E' quasi portatile, se non fosse per la famosa chiave Trolltech. Ne ho approfittato per crearne una versione modificata in cui, fra le altre cose, viene impostato e normalizzato anche il percorso della cartella di Output. Test richiesto/Test needed: X-Lastar_1.3.1_rev1_test1 (8,49 MB) --- edit --- Rilasciato/released X-Lastar_1.3.1_rev1[ Edited Mon 27 May 2013 - 22:17 ] | ||
