Aggiornamento: X-Iron Go to page << >> |
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3358 | X-Iron 28.0.1550.0 Link winPenPack Aggiornamento dalla versione 27.0.1500.0 alla 28.0.1550.0 Home: -Link- Direct link: -Link- nota: testato con il vecchio X-launcher, mi pare tutto OK! --- edit zandet2 --- software wpp aggiornato [ Edited Fri 09 Aug 2013 - 20:35 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Iron 29.0.1600.10 Link winPenPack Aggiornamento dalla versione 28.0.1550.0 alla 29.0.1600.1 Home: -Link- Direct link: -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Fri 13 Sep 2013 - 19:30 ] | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3358 | testato con il vecchio launcher... non ho avuto problemi! si può aggiornare. | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Iron 30.0.1650.0 Link winPenPack Aggiornamento dalla versione 29.0.1600.1 alla 30.0.1650.0 Home: -Link- Direct link: -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Wed 23 Oct 2013 - 23:47 ] | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3358 | testato con vecchio launcher. TUTTO OK - AGGIORNABILE | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Iron 31.0.1700.0 Link winPenPack Aggiornamento dalla versione 30.0.1650.0 alla 31.0.1700.0 Home: -Link- Direct link: -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Fri 06 Dec 2013 - 22:51 ] | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | X-Iron 32.0.1750.1 Link winPenPack -Link- Aggiornamento dalla versione 31.0.1700.0 alla 32.0.1750.1 Home: -Link- SRWare Iron Support (English): -Link- Direct download installer: -Link- UPDATE: Iron 32.0.1750.1: - update to latest chromium base - fixes flash problems | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | X-Iron 32.0.1750.1 Testato con il vecchio launcher: NON FUNZIONA o per la precisione si vede che il launcher parte ma non avvia il programma. | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3358 | confermo quanto riscontrato da rbon !!! il nuovo Iron con il vecchio launcher non si avvia! [ Edited Fri 07 Mar 2014 - 18:39 ] | ||
