running multiple instances of x-firefox (29.0.1) |
Stijn |
Registered Member #8804 Joined: Thu 14 Feb 2008 - 11:21Posts: 4 | I tried to run 2x x-firefox using different combinations, e.g. copying x-firefox installation to a different directory, changing X-Firefox.ini by uncommenting MOZ_NO_REMOTE=1. Another time, I made a new profile for the 2nd copy and changed it in X-Firefox.ini too.... Furthermore I tried to use the parameter -no-remote in X-Firefox.ini... etc... But everytime, I receive the notice: "firefox is already running", or in English or in Italian using the -no-remote with firefox.exe in the bin\firefox directory works well. so it must be possible, only there seems a configuration problem with the x-version Being confused: who had been able to run multiple instances of x-firefox & what was the configuration? Many thanks, Stijn | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3358 | Hi Stijn, sorry for the delay of our answer, but I was pretty sure to have already answered yesterday afternoon, but I forgot to send my post after writing! Apologies Anyway, it is quite easy to solve your issue: in the "X-Firefox.ini" file You need to modify only the following parameter: MultipleIstances=true You can find it almost at the end of the ini file, in [Options] IMPORTANT NOTE: Be careful! Be sure to avoid starting at the same time an installed Firefox session and a X-Firefox session in two different istances Enabling MULTIPLE ISTANCES, the risk is to loose your original profile data in any INSTALLED firefox present on your PC. If You have ONLY X-Firefox on your PC, You are free of risks! PS: I don't remember if unidentiting MOZ_NO_REMOTE=1 is still working... Theoretically it'will work, but I don't use it anymore. Have a nice week-end [ Edited Fri 13 Jun 2014 - 08:47 ] | ||
Stijn |
Registered Member #8804 Joined: Thu 14 Feb 2008 - 11:21Posts: 4 | Hi Taf, Thanks for your reply. I tried this out. Using another copy of same x-firefox or launching it again, opens a new window, but doesn't launch a second executable with its own cache etc but only opens a new window. I did something wrong? | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3358 | Hi Stijn, You are right! I forgot to tell you one more info. To have a second executable with its own cache etc. (as per your request) you need to enable also: MOZ_NO_REMOTE=1 uncommenting it at least in one of 2 different X-firefox. I made some test right now: I have a X-Firefox with 24.6.0 ESR release and another one with latest version (30.0) with different settings and different extensions. Unsing: multipleIstances=true in both and MOZ_NO_REMOTE=1 in one of them, I'm able to run different executablen in same time hope this helps [ Edited Fri 13 Jun 2014 - 19:17 ] | ||
Stijn |
Registered Member #8804 Joined: Thu 14 Feb 2008 - 11:21Posts: 4 | Hi Taf, Thanks a lot. It works. I did the test by running 3x firefox: 1) multipleIstances=true in all x-firefox.ini and 2) MOZ_NO_REMOTE=1 in all but one Many thanks, Stijn | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3358 | Happy being helpful! | ||
