Aggiornamento: Ultradefrag Go to page >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | UltraDefrag 6.0.3 Link winPenPack Aggiornamento dalla versione 6.0.2 alla 6.0.3 Home: -Link- Direct link (32 bit) -Link- Dir ect link(64 bit): -Link- Risultato test: niente da segnalare [ Edited Thu 23 Oct 2014 - 08:31 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | UltraDefrag 6.0.4 Link winPenPack Aggiornamento dalla versione 6.0.3 alla 6.0.4 Home: -Link- Direct link (32 bit) -Link- Dir ect link(64 bit): -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | UltraDefrag 6.1.0 Link winPenPack Aggiornamento dalla versione 6.0.4 alla 6.1.0 Home: -Link- Direct link (32 bit) -Link- Dir ect link(64 bit): -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | UltraDefrag 6.1.1 Link winPenPack Aggiornamento dalla versione 6.1.0 alla 6.1.1 Home: -Link- Direct link (32 bit) -Link- Dir ect link(64 bit): -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | UltraDefrag 7.0.0 Link winPenPack Aggiornamento dalla versione 6.1.1 alla 7.0.0 Home: -Link- Direct link (32 bit) -Link- Dir ect link(64 bit): -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | UltraDefrag 7.0.1 Link winPenPack Aggiornamento dalla versione 7.0.0 alla 7.0.1 Home: -Link- Direct link (32 bit) -Link- Dir ect link(64 bit): -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | UltraDefrag 7.0.2 Link winPenPack Aggiornamento dalla versione 7.0.1 alla 7.0.2 Home: -Link- Direct link (32 bit) -Link- Dir ect link(64 bit): -Link- Risultato test: niente da segnalare | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1706 | Salve a tutti, scusate se non uso la normale procedura per segnalare gli aggiornamenti del programma ma c'è da far presente una cosa. Se andate sul sito del programma troverete DUE versioni del programma, una open source (l'ultima disponibile, la 7.1.1) e una commerciale (la 8.0). Scegliete voi se mantenere la versione open source oppure eliminare il programma. Non so se le prossime versioni saranno solo a pagamento, io comunque per dovere di cronaca ho preferito dirvelo. | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | UltraDefrag 7.1.1 Link winPenPack Aggiornamento dalla versione 7.0.2 alla 7.1.1 Home: -Link- Direct link (32 bit) -Link- Direct link(64 bit): -Link- Risultato test: niente da segnalare @eagleman: qui si supporta solo OPEN SOURCE - quindi la versione a pagamento NON verrà mai presa in considerazione [ Edited Mon 15 Oct 2018 - 11:06 ] | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1706 | UltraDefrag 7.1.3 Link winPenPack Aggiornamento dalla versione 7.1.1 alla 7.1.3 Home: -Link- Direct link (32 bit): -Link- Direct link(64 bit): -Link- [ Edited Sat 18 Jan 2020 - 15:27 ] | ||
