Aggiornamento: X-FileZilla Go to page << >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Prova adesso -Link- Leggi questo -Link- | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Grazie, Rcs. Ora è ok. Bisognerà ricordarsi di inserire il link giusto d'ora in poi. P. S.: aggiorno il software appena avrò modificato il launcher. C'è qualche bug sulla normalizzazione dei percorsi. | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-FileZilla 3.10.3 winPenPack link Aggiornamento dalla versione 3.10.2 alla 3.10.3 Home: -Link- Direct Link: (not portable) -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-FileZilla 3.11.0 winPenPack link Aggiornamento dalla versione 3.10.3 alla 3.11.0 Home: -Link- Direct Link: (not portable) -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-FileZilla 3.11.0.1 winPenPack link Aggiornamento dalla versione 3.11.0 alla 3.11.0.1 Home: -Link- Direct Link: (not portable) -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-FileZilla 3.11.0.2 winPenPack link Aggiornamento dalla versione 3.11.0.1 alla 3.11.0.2 Home: -Link- Direct Link: (not portable) -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-FileZilla 3.12.0 winPenPack link Aggiornamento dalla versione 3.11.0.2 alla 3.12.0 Home: -Link- Direct Link: (not portable) -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-FileZilla 3.12.0.2 winPenPack link Aggiornamento dalla versione 3.12 alla 3.12.0.2 Home: -Link- Direct Link: (not portable) -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-FileZilla 3.13.0 winPenPack link Aggiornamento dalla versione 3.12.0.2 alla 3.13.0 Home: -Link- Direct Link: (not portable) -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-FileZilla 3.13.1 winPenPack link Aggiornamento dalla versione 3.13.0 alla 3.13.1 Home: -Link- Direct Link: (not portable) -Link- | ||
