Sponsored Links
SystoTech PDF Split and Merge
Mon 21 Dec 2015 - 11:37
Registered Member #41915
Software name: SystoTech PDF Split and Merge
Product Page:
Direct Link to download:
File size: 2.0 MB = 2097152 Bytes
Author name: SystoTech
Author website:
Description: SystoTech PDF Split and Merge is a handy Application used to Split and Merge the multiple PDF Files at once. It is a standalone application that does not requires the installation of Adobe Acrobat. For splitting the PDF files, the software works in three different modes (Split PDF by Page Range, Create separate PDF file for each available pages, Create PDF files of desired number of pages). The users can easily merge multiple PDF files at once by just browsing the PDF files and clicking on Merge button
Version: 1.0
License: Freeware
Screenshot #1:
Screenshot #2:
Screenshot #3:
