Aggiornamento: [librerie] Java SE Runtime Environment
Go to page   <<        >>
Wed 20 Apr 2016 - 20:40
Registered Member #675
Java SE Runtime Environment 8 Update 91
Link winPenPack
Aggiornamento dalla versione 8 Update 77 alla 8 Update 91
Home: -Link-
Direct link (32 bit): -Link-
Direct link (64 bit): -Link-
Tue 19 Jul 2016 - 23:35
Java SE Runtime Environment 8 Update 101
Link winPenPack
Aggiornamento dalla versione 8 Update 91 alla 8 Update 101
Home: -Link-
Tue 18 Oct 2016 - 22:17
Java SE Runtime Environment 8 Update 121
Link winPenPack
Aggiornamento dalla versione 8 Update 111 alla 8 Update 121
Home: -Link-
[ Edited Wed 18 Jan 2017 - 20:39 ]
Mon 08 May 2017 - 20:12
Java SE Runtime Environment 8 Update 131
Link winPenPack
Aggiornamento dalla versione 8 Update 121 alla 8 Update 131
Home: -Link-
Sun 23 Jul 2017 - 02:32
Java SE Runtime Environment 8 Update 141
Link winPenPack
Aggiornamento dalla versione 8 Update 131 alla 8 Update 141
Home: -Link-
Fri 18 Aug 2017 - 23:10
Java SE Runtime Environment 8 Update 144
Link winPenPack
Aggiornamento dalla versione 8 Update 141 alla 8 Update 144
Home: -Link-
rbon
Mon 01 Mar 2021 - 16:19
Registered Member #4134
Java SE Runtime Environment 8 Update 281
Link winPenPack -Link-
Aggiornamento dalla versione 8 Update 144 alla 8 Update 281
Home: -Link-
Direct link (32 bit) not portable: -Link-
Direct link (64 bit) not portable: -Link-
Java JRE for Windows: Java JRE for Windows released on January 19, 2021
Softpedia: -Link-
Nota
Java è richiesta da programmi come X-LibreOffice.
Non so se il programma JavaGet -Link- scarica automaticamente l'ultima versione stabile.
rbon
Sun 23 Oct 2022 - 16:26
Java SE Runtime Environment 8 Update 351
Aggiornamento dalla versione 8 Update 281 alla 8 Update 351
web site: -Link-
Download page: -Link-
Direct download (32 bit) not portable: -Link-
Direct download (64 bit) not portable: -Link-
Release date: October 18, 2022
Softpedia: -Link-
Come aggiornare JRE su X-LibreOffice:
Per aggiornare Jave RE su X-LibreOffice:
-> guardate dentro la cartella \Lib (che contiene le librerie)
dovreste vedere le sottocartelle:
--> 7za
--> Fonts
--> Java
cancellate senza indugio la sottocartella Java ed avviate X-LibreOffice.
Il launcher vi avviserà che le librerie Java sono mancanti e si offrirà di scaricarle (l'ultima versione): rispondete SI e il launcher farà il lavoro per voi.
Ho notato che ad ogni release di Jave SE Runtime Environment, X-LibreOffice si avvia più velocemente: ciò è sicuramente dovuto al codice più ottimizzato presente nelle nuove versioni delle librerie.
rbon
Wed 18 Jan 2023 - 21:21
Java SE Runtime Environment 8 Update 361
Aggiornamento dalla versione 8 Update 351 alla 8 Update 361
web site: -Link-
Direct download (32 bit) exe installer: jre-8u361-windows-i586.exe
Direct download (64 bit) exe installer: jre-8u361-windows-x64.exe
GitHub project 'java_download.sh': -Link-
Direct download (32 bit) portable: jre-8u361-windows-i586.tar.gz
Direct download (64 bit) portable: jre-8u361-windows-x64.tar.gz
Release date: January 17, 2023
Softpedia: -Link-
--> 7za
--> Fonts
--> Java
Nota su versioni portatili (tarball):
sulla pagina del progetto 'java_download.sh' cercare i post dell'utente Nadwey
[ Edited Fri 27 Jan 2023 - 16:16 ]
Tue 18 Apr 2023 - 20:00
Registered Member #9
Java SE Runtime Environment 8 Update 371
Aggiornamento dalla versione 8 Update 361 alla 8 Update 371
web site: -Link-
Direct download (32 bit) exe installer: jre-8u371-windows-i586.exe
Direct download (64 bit) exe installer: jre-8u371-windows-x64.exe
Direct download (32 bit) portable: jre-8u371-windows-i586.tar.gz
Direct download (64 bit) portable: jre-8u371-windows-x64.tar.gz
Release date: April, 18 2023
Softpedia: -Link-
--> 7za
--> Fonts
--> Java
Go to page   <<        >>
