Make X-ApacheOpenoffice 4.1.4 available? |
| plino |
![]() ![]() Registered Member #41473 Joined: Wed 19 Jun 2013 - 16:11Posts: 17 | Would it be possible to release a new version based on AOO 4.1.4? -Link- ![]() Thanks! | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | I released the 4.1.5 version -Link- ![]() | ||
| plino |
![]() ![]() Registered Member #41473 Joined: Wed 19 Jun 2013 - 16:11Posts: 17 | Danix wrote ... I released the 4.1.5 version Thank you very much! I have downloaded and tested under Windows 7 Pro x64 and it works perfectly. Thank you for listening to user's requests! Best regards! | ||
| Taf |
![]() ![]() ![]() Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3379 ![]() | YW, plino. little by little and step by step, we TRY to follow user's requests. ![]() [ Edited Mon 08 Jan 2018 - 16:23 ] | ||
| plino |
![]() ![]() Registered Member #41473 Joined: Wed 19 Jun 2013 - 16:11Posts: 17 | Taf wrote ... little by little and step by step, we TRY to follow user's requests. That is all anyone can ask. Alternatively people can volunteer to do the work themselves BTW if you guys have a cookbook for creating the Apache OpenOffice Portable release I volunteer to contribute to future builds Best regards! | ||
| plino |
![]() ![]() Registered Member #41473 Joined: Wed 19 Jun 2013 - 16:11Posts: 17 | Hi guys Returning to this post from 2018... Can I help to create a 4.1.6 and a 4.1.7 X-ApacheOpenOffice build? Having portable versions of previous versions is quite useful for testing regressions (and X-ApacheOpenOffice builds are much better than portable versions from "another" source) | ||
