Aggiornamento: PeaZip Go to page << >> |
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1724 | Peazip 7.9.0 Link WinPenPack Aggiornamento dalla versione 7.8.0 alla 7.9.0 Home: -Link- Direct download windows 32 bit: -Link- Direct download windows 64 bit: -Link- | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1724 | Peazip 8 Link WinPenPack Aggiornamento dalla versione 7.9.0 alla 8.0.0 Home: -Link- Direct download windows 32 bit: -Link- Direct download windows 64 bit: -Link- | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1724 | Peazip 8.1 Link WinPenPack Aggiornamento dalla versione 8.0.0 alla 8.1.0 Home: -Link- Direct download windows 32 bit: -Link- Direct download windows 64 bit: -Link- | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1724 | Peazip 8.2 Link WinPenPack Aggiornamento dalla versione 8.1.0 alla 8.2.0 Home: -Link- Direct download windows 32 bit: -Link- Direct download windows 64 bit: -Link- | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1724 | Peazip 8.3.0 Link WinPenPack Aggiornamento dalla versione 8.2.0 alla 8.3.0 Home: -Link- Direct download windows 32 bit: -Link- Direct download windows 64 bit: -Link- | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1724 | Peazip 8.4.0 Link WinPenPack Aggiornamento dalla versione 8.3.0 alla 8.4.0 Home: -Link- Direct download windows 32 bit: -Link- Direct download windows 64 bit: -Link- | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | Peazip 8.5.0 Link WinPenPack Aggiornamento dalla versione 8.4.0 alla 8.5.0 web site: -Link- PeaZip for Windows Portable: -Link- GitHub download page for all versions: -Link- Direct download Windows 32 bit Portable: -Link- Direct download Windows 64 bit Portable: -Link- Release date: February 20, 2022 Softpedia: -Link- Major Geeks: -Link- Changelog for rel. 8.5.0: La release PeaZip 8.5.0 migliora i pacchetti per la piattaforma macOS, con scorciatoie da tastiera in stile macOS, integrazione con il menu contestuale di macOS, pieno supporto all'eliminazione "sposta nel cestino" (sia da file manager, sia dopo operazioni di compressione/estrazione) e supporto per backend Brotli, Zpaq e Zstandard. L'integrazione del sistema macOS è completamente eseguibile tramite script tramite gli script .workflow di Automator, vedi menu di servizio di esempio nella cartella (peazip)/res/share/batch. File manager è stato migliorato e ora consente più stili alternativi (elenco grande e dettagli grandi) su Linux. È ora possibile integrare opzionalmente PeaZip nel mini menu contestuale di Windows 11 dagli script .reg nella cartella (peazip)/res/share/batch. Questa versione migliora la creazione di script, l'utilizzo dei layout (file che definiscono filtri avanzati di inclusione ed esclusione e, facoltativamente, l'elenco di input) e aggiorna le impostazioni di compressione. Backend aggiornati: 7z 21.07, Pea 1.06 e Zstd 1.5.2. B.T.W.: Per visualizzare una pagina di GitHub in una lingua a scelta (diversa dalla propria): 1. accedere a GitHub con il browser Chromium 2. premere il bottone nero (traduci questa pagina), a destra nella barra degli indirizzi, prima della stella per aggiungere il link ai preferiti. | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1724 | Il sito nella scheda di download è sbagliato. Quello giusto è -Link- | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3358 | Grazie mille! Sistemato. | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1724 | Peazip 8.6.0 Link WinPenPack Aggiornamento dalla versione 8.5.0 alla 8.6.0 Home: -Link- Direct download windows 32 bit: -Link- Direct download windows 64 bit: -Link- [ Edited Wed 13 Apr 2022 - 11:02 ] | ||
