Aggiornamento: [librerie] Java SE Runtime Environment
Go to page   <<
rbon
Wed 19 Apr 2023 - 17:49
Registered Member #4134
eagleman wrote ...
Java SE Runtime Environment 8 Update 371
Link winPenPack -Link-
Aggiornamento dalla versione 8 Update 361 alla 8 Update 371
I links per il download di Java SE Runtime Environment sono tutti sbagliati.
I links corretti sono:
web site: -Link-
Download page: -Link-
Direct download (32 bit) exe installer: jre-8u371-windows-i586.exe
Direct download (64 bit) exe installer: jre-8u371-windows-x64.exe
GitHub project 'java_download.sh': -Link-
Direct download (32 bit) portable: jre-8u371-windows-i586.tar.gz
Direct download (64 bit) portable: jre-8u371-windows-x64.tar.gz
Release date: April 18, 2023
Softpedia: -Link-
Il resto delle note va bene.
Thu 20 Apr 2023 - 12:14
scheda sistemata. Grazie!
rbon
Fri 21 Apr 2023 - 18:04
Taf wrote ...
grazie a te.
Tue 18 Jul 2023 - 20:27
Registered Member #9
Java SE Runtime Environment 8 Update 381
Aggiornamento dalla versione 8 Update 371 alla 8 Update 381
web site: -Link-
Release date: July 18, 2023
[ Edited Thu 20 Jul 2023 - 08:25 ]
rbon
Thu 20 Jul 2023 - 18:54
web site: -Link-
Direct download (32 bit) portable: jre-8u381-windows-i586.tar.gz
Direct download (64 bit) portable: jre-8u381-windows-i586.tar.gz
rbon
Tue 17 Oct 2023 - 19:23
Java SE Runtime Environment 8 Update 391
Aggiornamento dalla versione 8 Update 381 alla 8 Update 391
web site: -Link-
Direct download (32 bit) Installer: jre-8u391-windows-i586.exe
Direct download (64 bit) Installer: jre-8u391-windows-x64.exe
Direct download (32 bit) Portable: jre-8u391-windows-i586.tar.gz
Direct download (64 bit) Portable: jre-8u391-windows-x64.tar.gz
Release date: October 17, 2023
Nota per gli utilizzatori di X-LibreOffice:
1. Rinominate la cartella 'jre1.8.0_381' in ''jre1.8.0_391'' (si trova dentro \Lib\Java)
2. cancellate il contenuto della cartella 'jre1.8.0_391' appena rinominata
3. scompattare la versione Portable (32 oppure 64 bit) all'interno di detta cartella
4. avviate LibreOffice, poi
--> Strumenti --> Opzioni --> Avanzate --> cercate la cartella 'jre1.8.0_391' e confermate con OK
5. chiudete e poi riavviate X-LibreOffice
rbon
Tue 16 Jan 2024 - 20:31
Java SE Runtime Environment 8 Update 401
Aggiornamento dalla versione 8 Update 391 alla 8 Update 401
web site: -Link-
Direct download (32 bit) Portable: jre-8u401-windows-i586.tar.gz
Direct download (64 bit) Portable: jre-8u401-windows-x64.tar.gz
Release date: January 16, 2024
Tue 16 Apr 2024 - 23:46
Java SE Runtime Environment 8 Update 411
Aggiornamento dalla versione 8 Update 401 alla 8 Update 411
web site: -Link-
Release date: April 16, 2024
rbon
Fri 19 Apr 2024 - 17:06
Java SE Runtime Environment 8 Update 411 Portable
web site: -Link-
Direct download (32 bit) Portable: jre-8u411-windows-i586.tar.gz
Direct download (64 bit) Portable: jre-8u411windows-x64.tar.gz
Go to page   <<
