Aggiornamento: X-SQLyog Go to page << >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-SQLyog 8.02 Link winPenPack Aggiornamento dalla versione 8.01 alla 8.02 Home: -Link- Download page: (not portable) -Link- (bisogna inserire indirizzo e-mail per scaricare) [ Edited Fri 10 Apr 2009 - 21:49 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-SQLyog 8.03 Link winPenPack Aggiornamento dalla versione 8.02 alla 8.03 Home: -Link- Download page: (not portable) -Link- (bisogna inserire indirizzo e-mail per scaricare) [ Edited Fri 10 Apr 2009 - 21:49 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-SQLyog 8.04 Link winPenPack Aggiornamento dalla versione 8.03 alla 8.04 Home: -Link- Download page: (not portable) -Link- (bisogna inserire indirizzo e-mail per scaricare) [ Edited Fri 10 Apr 2009 - 21:49 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-SQLyog 8.05 Link winPenPack Aggiornamento dalla versione 8.04 alla 8.05 Home: -Link- Download page: (not portable) -Link- (bisogna inserire indirizzo e-mail per scaricare) --- edit zandet2 --- software wpp aggiornato [ Edited Fri 10 Apr 2009 - 21:48 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-SQLyog 8.1 Link winPenPack Aggiornamento dalla versione 8.05 alla 8.1 Home: -Link- Download page: (not portable) -Link- (bisogna inserire indirizzo e-mail per scaricare) [ Edited Fri 21 Aug 2009 - 10:42 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-SQLyog 8.11 Link winPenPack Aggiornamento dalla versione 8.1 alla 8.11 Home: -Link- Download page: (not portable) -Link- (bisogna inserire indirizzo e-mail per scaricare) [ Edited Fri 21 Aug 2009 - 10:42 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-SQLyog 8.12 Link winPenPack Aggiornamento dalla versione 8.11 alla 8.12 Home: -Link- Download page: (not portable) -Link- (bisogna inserire indirizzo e-mail per scaricare) [ Edited Fri 21 Aug 2009 - 10:43 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-SQLyog 8.13 Link winPenPack Aggiornamento dalla versione 8.12 alla 8.13 Home: -Link- Download page: (not portable) -Link- (bisogna inserire indirizzo e-mail per scaricare) [ Edited Fri 21 Aug 2009 - 10:43 ] | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | E' disponibile in download nel sito la versione 8.14, che però è diventata "Trial"; per scaricare la versione "full" bisogna aver acquistato un altro software. Chiedo conferma (non usando questo software): la versione Trial è limitata o ha comunque le stesse funzionalità delle versioni segnalate qui precedentemente? --- edit --- Mi auto-rispondo: SI Dalle FAQ del sito: -Link- Are there restrictions in the Enterprise TRIAL compared to the REGISTERED version? Yes! The restrictions are: * In the startup as well as in exit it will show a window displaying how many days left in the trial period. * Once the trial period is over it will exit immediately after showing the trial period expired window. The connection window will not appear. * Data Sync will allow to sync only two tables per job executed. * Scheduled Backup will allow only two objects to be exported per job executed. The two objects may be of identical type or different type (Tables, Stored Procedures etc.) * Import External Data Tool will allow only 2 tables to be imported/migrated per job executed. Se le premesse sono confermate, il software è destinato alla rimozione... [ Edited Thu 20 Aug 2009 - 17:13 ] | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | Correzione: la versione "community" è disponibile su GoogleCode. Quindi: X-SQLyog 8.14 Link winPenPack Aggiornamento dalla versione 8.13 alla 8.14 Home: -Link- Progetto su GoogleCode: -Link- Download page: (not portable) -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Fri 21 Aug 2009 - 10:41 ] | ||
