[Player] Voodoo Player |
icemax |
Registered Member #194 Joined: Sun 21 Jan 2007 - 22:27Posts: 1371 | Nome Software:Voodoo Player Direct Link al download: -Link- Dimensione File: 478 KB (489742) Nome autore: Dmitry «Vortex» Dudikoff eMail autore: -eMail- Sito Web Autore: -Link- Descrizione: Voodoo Player è un lettore di file multimediali in soli 480 KB che non necessita di codec esterni per visualizzare i filmati o riprodurre i file audio. Supporta oltre 30 formati di file multimediali, inclusi Mp3, DVD e DivX, permette la riproduzione anche a velocità superiori ed inferiori, esegue screen-shots dei fotogrammi , supporto per i sottotitoli - Crea playlist, ne esegue la ricerca e crea segnalibri. Portable tips how-to: Decomprimere il file compresso.[Il programma salva le proprie impostazioni neli file : VP.xml] Versione:v1.0.build-211_rc-2 Licenza: Open source GPL codice sorgente su richiesta inviando una email a : -eMail- -Link- Compatibilità Sistemi operativi : Windows 2000 e XP. Richiede DirectX 9 o superiore. [INFO ORIGINALI] Equipped with Voodoo Player, you with easy can: play over 30 multimedia formats, including MP3, DVD and DivX. seek in the media, rewind and fast-forward. change sound volume and balance. watching playing media position and duration. switch to full-screen mode and back to windowed mode. adjust brightness, contrast, saturation and HUE. change playing rate from normal to slowest or fastest. step through a video as slowly as one frame at a time. create screen-shots to file otherwise to clipboard. see current time. zoom movie and change aspect ratio. change internal components(filters) properties. create play lists, search by name, sort by duration/size/path or randomly. extended features for playlist: "shuffle" and "jump". set bookmarks. view subtitles. attach addinitional sound files (translation). see detailed information(as which video codec used, file size, avi tags, which audio codec used, and more) about video file. Voodoo Player - is the small and fast video player for Windows 2000/NT/XP. Written on Borland Delphi® 2006. Project Admins: vort3x Operating System: 32-bit MS Windows (NT/2000/XP) License: GNU General Public License (GPL) Category: Display, Usability [ Edited Thu 05 Feb 2009 - 22:34 ] | ||
deep |
Registered Member #7 Joined: Sat 20 Jan 2007 - 20:57Posts: 568 | Come fa a contenere tutti i codec necessari in soli 480 kb di peso? | ||
icemax |
Registered Member #194 Joined: Sun 21 Jan 2007 - 22:27Posts: 1371 | the BIG question ????? bhoooooooooooooooooo !! il nome : Voodoo .. la dice lunga .... p.s. ho aggiornato i dettagli : leggi le caratteristiche : qui sotto la guida : Using player How to open video file There are number of ways to open video: 1. You can click "^" button, select file you want to play, then press OK. 2. You can press F3, select file you want to play, then press OK. 3. You can drag file from explorer window and drop it to player. If you drop file on video area currently playing media will be immediately stopped and new file is loaded. If you drop file on playlist area it will be added to the end of playlist. 4. You can double-click to video file to start playing immediately. This option is available after registering file types. How to switch to full screen mode You can use player in windowed or full-screen mode. To switch between these options you can press Enter, or click by middle mouse button on the video. How to control sound volume You can adjust sound volume by rolling mouse wheel. The same action can be done by pressing Up and Down arrow keys on the keyboard. You can set desired audio level by clicking directly on sound volume slider. Also you can quickly switch sound off by pressing M on keyboard. How to seek in a video You can seek to the desired playback just by clicking on the position slider. Also you can do it from keyboard by Left and Right arrow keys. Key Backspace will remind video to the begin. Key Space will set video to pause. Video color control When playing video you can adjust brightness, contrast, saturation and HUE by the following keyboard shurtcuts: Numpad "+" and "-" - color brightness. Ctrl + Numpad "+" and "-" - color contrast Alt + Numpad "+" and "-" - color saturation Shift + Numpad "+" and "-" - color HUE Default keyboard shortcuts You can easily change them in Preferences->Keyboard. Player control: Esc - close player F3 - open file F7 - search for DVD disk / - close file Tilde(~) - hide/show control panel and mouse P - show playlist End - minimize player A - stay on top of all windows F1 - about Voodoo Player I - file information W - maximize F10 - preferences menu Playback control: Space - toogle between Play and Stop Backspace - Rewind to the begin of the video Left/Right - rewind, forward by 3 second by default Shift + Left/Right - rewind, forward by 30 seconds by default Ctrl + Left/Right - rewind, forward by one frame Sound control: Up/Down - change audio level M - sound on/off Video Control: Enter - switch full-screen mode on/off Home - resize window to original movie size and move it to screen center +/- - zoom video 1, 2, 3 - aspect ratio: FullScreen, WideScreen and Stretched F11 - screenshot to a file F12 - screenshot to clipboard Playlist control: PgUp, PgDn - play previous or next by list Insert - add file(s) to playlist Shift+Insert - add folder to playlist Shift+Delete - clear playlist Ctrl+Home - sort playlist Delete - delete from playlist S - shuffle feature J - jump feature See Preferences->Keyboard "Action" drop-down list for more shorcuts. [ Edited Sun 01 Jul 2007 - 16:55 ] | ||
Bourne |
Registered Member #4287 Joined: Fri 20 Apr 2007 - 16:55Posts: 571 | Non e' completamente portabile perche' riproducendo un movie crea questo ini (cmq quasi irrilevante): C:\Documents and Settings\<user>\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini Per quanto riguarda la sua capacita' di riprodurre i vari movie, e' dovuto al fatto che usa i filtri directX installati sul sistema. ciao | ||
Moticanus |
Registered Member #4618 Joined: Thu 10 May 2007 - 08:29Location: Modica Posts: 1352 | icemax wrote ... Nome Software:Voodoo Player Direct Link al download: -Link- Dimensione File: 478 KB (489742) Nome autore: Dmitry «Vortex» Dudikoff eMail autore: -eMail- Sito Web Autore: -Link- Non presenti altri aggiornamenti. Sito dell'autore NON AVAILABLE. Sito su Sourceforge non aggiornato da marzo 2007. | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | Il software è in download: sezione Lettori Multimediali - Voodoo Player 1.0 | ||
