Aggiornamento: X-GimpGo to page << >> |
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | X-Gimp 2.6.3 Link winPenPack Aggiornamento dalla versione 2.6.2 alla 2.6.3 Home: - -Link- ![]() Direct Link: (not portable) -Link- ![]() [ Edited Wed 03 Dec 2008 - 01:36 ] | ||
| eagleman |
![]() ![]() Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 410 ![]() | X-Gimp 2.6.4 Link winPenPack Aggiornamento dalla versione 2.6.3 alla 2.6.4 Home: -Link- ![]() Direct Link: (not portable) -Link- ![]() ==EDIT zandet2== software wpp aggiornato [ Edited Fri 02 Jan 2009 - 13:22 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | X-Gimp 2.6.5 Link winPenPack Aggiornamento dalla versione 2.6.4 alla 2.6.5 Home: -Link- ![]() Direct Link: (not portable) -Link- ![]() [ Edited Tue 17 Feb 2009 - 14:39 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | X-Gimp 2.6.6 Link winPenPack Aggiornamento dalla versione 2.6.5 alla 2.6.6 Home: -Link- ![]() Direct Link: (not portable) -Link- ![]() [ Edited Sun 22 Mar 2009 - 12:50 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | X-Gimp 2.6.7 Link winPenPack Aggiornamento dalla versione 2.6.6 alla 2.6.7 Home: -Link- ![]() Direct Link: (not portable) -Link- ![]() [ Edited Tue 18 Aug 2009 - 18:39 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12452 ![]() | Test richiesto per conferma: questa versione (installata o estratta con UE) ha problemi con lo splash screen originale: lo splash non viene mostrato all'avvio. | ||
![]() ![]() ![]() Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3819 ![]() | Ciao Danix, confermo solo parzialmente: su Vista, se estraggo con UE ed eseguo, lo splash screen non viene visualizzato, ma se installo ed eseguo, invece, si. Ho anche provato a copiare l'installazione su un altro disco, disinstallare ed eseguire la copia: lo splash screen viene visualizzato (magari l'unistall non ha cancellato proprio tutto, non saprei). Avevo notato che nelle Proprietà della voce di menu di Gimp (versione installata), la cartella "Da" risultava essere "%USERPROFILE%\Pictures", ma siccome anche la copia (che non ha questa opzione) funziona, non so quanto possa essere significativa questa cosa... Sentiamo se qualcun altro ha qualcosa da aggiungere. Cordialmente ZioZione | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12452 ![]() | Hai ragione ZioZione, se il programma viene installato anzichè estratto, lo splash funziona. | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | X-Gimp 2.6.8 Link winPenPack Aggiornamento dalla versione 2.6.7 alla 2.6.8 Home: -Link- ![]() Direct Link: (not portable) -Link- ![]() [ Edited Sun 31 Jan 2010 - 23:58 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | X-Gimp 2.6.9 Link winPenPack Aggiornamento dalla versione 2.6.8 alla 2.6.9 Home: -Link- ![]() Direct Link: (not portable) -Link- ![]() | ||
