Aggiornamento: Cpu-ZGo to page >> |
| sceicco |
![]() ![]() Registered Member #5022 Joined: Tue 05 Jun 2007 - 08:51Posts: 385 | Cpu-Z 1.40.5 Link winPenPack Aggiornamento dalla versione 1.40 alla versione 1.40.5 Home: -Link- ![]() Direct Link: -Link- ![]() [ Edited Fri 03 Aug 2007 - 01:14 ] | ||
| alchimista |
![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | Cpu-Z 1.41 Link winPenPack Aggiornamento dalla versione 1.40.5 alla 1.41 Home: -Link- ![]() Direct Link: -Link- ![]() Postato da Rcs Edit by Alchimista spostato in un Thread già esistente. | ||
| alchimista |
![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | CPU-Z 1.42 Link winPenPack Aggiornamento dalla versione 1.41 alla 1.42 Home: -Link- ![]() Direct Link: -Link- ![]() Postato da Rcs Edit by Alchimista spostato in un Thread già esistente. | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | CPU-Z 1.43 Link winPenPack Aggiornamento dalla versione 1.42 alla 1.43 Home: -Link- ![]() Direct Link: -Link- ![]() | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | CPU-Z 1.44 Link winPenPack Aggiornamento dalla versione 1.43 alla 1.44 Home: -Link- ![]() Direct Link: -Link- ![]() | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | CPU-Z 1.44.1 Link winPenPack Aggiornamento dalla versione 1.44 alla 1.44.1 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: Allego log di regshot cpuz.zip | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Ma hai salvato un log in Documenti?
C:\Documents and Settings\Utente\Documenti\cpuz.txt
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Si! ho salvato per fare una prova. Ciao! | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Quindi ovvio che appare nel log... Comunque è ok ![]() | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | CPU-Z 1.44.2 Link winPenPack Aggiornamento dalla versione 1.44.1 alla 1.44.2 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: niente da segnalare [ Edited Sat 29 Mar 2008 - 16:58 ] | ||
