[Removed] Event Log Explorer |
Ketty |
Registered Member #5089 Joined: Sat 09 Jun 2007 - 02:27Posts: 1461 | Event Log Explorer (wpp Expert) -Link- Motivazione E' Shareware HKEY_CURRENT_USER\Software\EventLogXP\Event Log Explorer con 7 sottocartelle Chiave aggiunta:17 HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\ASProtect HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\ASProtect\SpecData HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\EventLogXP HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\EventLogXP\Event Log Explorer HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\EventLogXP\Event Log Explorer\Confirmations HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\EventLogXP\Event Log Explorer\Document HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\EventLogXP\Event Log Explorer\General HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\EventLogXP\Event Log Explorer\LogFile HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\EventLogXP\Event Log Explorer\ReportParams HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\EventLogXP\Event Log Explorer\UIParams HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\EventLogXP\Event Log Explorer\Updates [ Edited Fri 13 Jul 2007 - 19:57 ] | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Essendo disponibile l'aggiornamento Version: 2.2 beta 3 Released: 14-Jul-2007 prima di segnalarlo ho controllato, come faccio sempre, nel forum, ho trovato questo post di Ketty, sono andato a vedere sul sito e riporta questo: Free license You can get a FREE license of Event Log Explorer for personal non-commercial use. Free license allows you to use Event Log Explorer on your home computer or in a home network. Free version has only limitation - you cannot add more then 3 computers to the tree. Free license expires on 2007 December, 31. After the expiration you can get a new free license again. attendo info e se volete controllare, questo è il -Link- [ Edited Sun 15 Jul 2007 - 10:10 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Come si fa ad acquisire la licenza free? C'è un modulo? O avviene on line tramite il programma? | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | al link sopra indicato c'è un modulo per la richiesta | ||
