[Fixed] Agent Ransack |
Ketty |
Registered Member #5089 Joined: Sat 09 Jun 2007 - 02:27Posts: 1461 | Agent Ransack (wpp 128/256/512/school/espert) -Link- Motivazione HKEY_CURRENT_USER\Software\Agent_EXE\Agent Ransack e relative sottocartelle Chiave aggiunta:8 ---------------------------------- HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\Agent_EXE HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\Agent_EXE\Agent Ransack HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\Agent_EXE\Agent Ransack\Options HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\Agent_EXE\Agent Ransack\RecentContains HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\Agent_EXE\Agent Ransack\RecentFileName HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\Agent_EXE\Agent Ransack\RecentFolders HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\Agent_EXE\Agent Ransack\Settings HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\Agent_EXE\Agent Ransack\Window Settings ---------------------------------- Valore aggiunto:20 [ Edited Mon 16 Jul 2007 - 00:56 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Fixed: -Link- Su autorizzazione dell'autore, David Vest, è stata rilasciata una versione "X" [ Edited Mon 16 Jul 2007 - 00:52 ] | ||
MAXPC72 |
Registered Member #4454 Joined: Mon 30 Apr 2007 - 16:35Posts: 88 | a me continua a dare problemi... quando dal menu' winpen clicco su X-AgentRansack mi da: ERROR! F:WINPENPACK\Bin\AgentRansack\AgentRansack.exe not found! dando OK poi mi da questo msg: Please check options in “F:\WINPENPACK\XDrive\x-AgentRansack.ini ho trovato che nel INI c'e' questa riga sbagliata: [FileToRun]PathToExe=$Bin$\$AppName$\$AppName$.exe da correggere ,se non sbaglio, con: [FileToRun]PathToExe=$Bin$\$AppName$\AgentRansack.exe ma anche cosi' sembra non andare, cos'altro devo cambiare? | ||
Ketty |
Registered Member #5089 Joined: Sat 09 Jun 2007 - 02:27Posts: 1461 | Ho provato ad inserirlo nel mio wpp personalizzato e non mi da nessun problema. Nella cartella X-Drive devi mettere: X-AgentRansack.exe X-AgentRansack.ini e trascinare X-AgentRansack.exe nel menù per lanciarlo | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | MAXPC72 wrote ... da correggere ,se non sbaglio, con: [FileToRun]PathToExe=$Bin$\$AppName$\AgentRansack.exe ma anche cosi' sembra non andare, cos'altro devo cambiare? Non è sbagliata ed è ovvio che non va. Se AppName=AgentRansack, è uguale Credo che Ketty abbia individuato perfettamente il problema invece...oppure non hai inserito correttamente la cartella del programma in \Bin [ Edited Tue 17 Jul 2007 - 19:06 ] | ||
MAXPC72 |
Registered Member #4454 Joined: Mon 30 Apr 2007 - 16:35Posts: 88 | ...non ho capito cosa sia successo..., i file erano inseriti correttamente come ha detto ketty, ho sovrascritto di nuovo i file dello zip a quelli della pen, chiuso il menu' e poi ripaerto, adesso va tutto.BOH!! grazie cmq. | ||
littlenerd |
Guest | Hi, sorry that i dont speak italian Anyone know how to make a working shortcut for AgentRansack to the "Send To" menu? So i can open a folder in AgentRansack with rightclick -> sendto -> AgentRansack ? thx in advance | ||
