[Fixed] X-InnoSetup |
| Ketty |
![]() ![]() Registered Member #5089 Joined: Sat 09 Jun 2007 - 02:27Posts: 1461 | X-InnoSetup (wpp expert) -Link- ![]() Motivazione HKEY_CURRENT_USER\Software\Jordan Russell Chiave aggiunta:1 ---------------------------------- HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\Jordan Russell [ Edited Sun 15 Jul 2007 - 19:44 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Fixed: -Link- ![]() [ Edited Sun 15 Jul 2007 - 19:39 ] | ||
| phant0mw0rm |
![]() ![]() Registered Member #5039 Joined: Wed 06 Jun 2007 - 12:08Posts: 73 | Non so se è questo il posto giusto per la mia domanda.. Come devo fare a tradurre X-InnoSetup in italiano? Il file con la traduzione c'è già, ma anche seguendo la guida non riesco proprio a farlo funzionare.. ![]() | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Non è il posto giusto. Sarebbe il caso di aprire un nuovo topic in "Supporto X-Software Portable Software". | ||
| tDJ |
![]() ![]() ![]() Registered Member #9527 Joined: Fri 07 Mar 2008 - 17:36Posts: 12 | Inno Setup v5.2.3 -Link- ![]() Update from version 5.2.2 to version 5.2.3 Home: -Link- ![]() Direct Link: -Link- ![]() | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | tDJ, please, use THIS FORUM SECTION for signal updates. The X-Innosetup update-thread is already present: -Link- ![]() Thank you. ![]() [ Edited Wed 12 Mar 2008 - 12:37 ] | ||
[Fixed] X-InnoSetup
