[Fixed] X-InnoSetup |
Ketty |
Registered Member #5089 Joined: Sat 09 Jun 2007 - 02:27Posts: 1461 | X-InnoSetup (wpp expert) -Link- Motivazione HKEY_CURRENT_USER\Software\Jordan Russell Chiave aggiunta:1 ---------------------------------- HKU\S-1-5-21-1993962763-963894560-839522115-1003\Software\Jordan Russell [ Edited Sun 15 Jul 2007 - 19:44 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12961 | Fixed: -Link- [ Edited Sun 15 Jul 2007 - 19:39 ] | ||
phant0mw0rm |
Registered Member #5039 Joined: Wed 06 Jun 2007 - 12:08Posts: 73 | Non so se è questo il posto giusto per la mia domanda.. Come devo fare a tradurre X-InnoSetup in italiano? Il file con la traduzione c'è già, ma anche seguendo la guida non riesco proprio a farlo funzionare.. | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12961 | Non è il posto giusto. Sarebbe il caso di aprire un nuovo topic in "Supporto X-Software Portable Software". | ||
tDJ |
Registered Member #9527 Joined: Fri 07 Mar 2008 - 17:36Posts: 12 | Inno Setup v5.2.3 -Link- Update from version 5.2.2 to version 5.2.3 Home: -Link- Direct Link: -Link- | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12961 | tDJ, please, use THIS FORUM SECTION for signal updates. The X-Innosetup update-thread is already present: -Link- Thank you. [ Edited Wed 12 Mar 2008 - 12:37 ] | ||
