WinPenPack and virus! |
sluice |
Registered Member #2584 Joined: Fri 09 Feb 2007 - 12:12Posts: 1 | I have just installed WinPenPack but my antivirus NOD32 has quarantined 2 files: pspv.exe as a Win32/PassView.163 application keyfinder.exe as a Win32/PSWTool.RAS.A application What do you suggest needs to be done? [ Edited Mon 16 Apr 2007 - 02:19 ] | ||
Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 | sluice wrote ... I have just installed WinPenPack but my antivirus NOD32 has quarantined 2 files: pspv.exe as a Win32/PassView.163 application keyfinder.exe as a Win32/PSWTool.RAS.A application What do you suggest needs to be done? Hi sluice, welcome to WPP forum!, it seems to be a "false positive" problem for these executables. In particular, the second one is a "potentially dangerous executable". Sometimes this problem occurs for UPX compressed executables (both native or X-Lancher one). But some anti-virus programs (i.e. NOD32) are recognizing also hackers tools as potentially dangerous. In fact, "Keyfinder is a freeware utility that retrieves your Product Key (cd key) used to install windows from your registry", and "PassView is a small utility that reveals the passwords stored on your computer by Internet Explorer, Outlook Express and MSN Explorer", so they could be used also for illegal uses. NOD32 don't know if you are legitimate to execute these softwares on your PC, so, for system safety, it quarantines them. WPP executables are accurately checked against all viruses before packaging (but Murphy Laws exists, so...). If there is a problem, I think that is not about a virus. Unfortunately, I don't know enough NOD32 to give you a solution about your problem. But if someone else could be more precise... Greetings ZioZione [ Edited Fri 09 Feb 2007 - 14:59 ] | ||
icemax |
Registered Member #194 Joined: Sun 21 Jan 2007 - 22:27Posts: 1371 | ehm... sluice wrote ... I have just installed WinPenPack but my antivirus NOD32 has quarantined 2 files: pspv.exe as a Win32/PassView.163 application Antivirus "False Positive" Problems helo ...please visit : www nirsoft net / false _ positive _ report . html from : -Link- Sometimes Antivirus scanner reports that a program is infected with a Virus or Trojan, even when the program is not really infected with any malicious code. This kind of problem is known as "False Positive" or "False Alert", and it's quite a common problem in some of the password recovery tools provided in NirSoft Web site. bye bye ..and thanks for download Winpenpack ps. WinPenPack is very very secure pack [ Edited Fri 09 Feb 2007 - 14:42 ] | ||
