Aggiornamento: CubicExplorer |
| alchimista |
![]() ![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | CubicExplorer 0.80 final ![]() Aggiornamento dalla versione 0.77a alla 0.80 final Home: -Link- ![]() Direct Link: -Link- ![]() [ Edited Fri 24 Aug 2007 - 23:02 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | CubicExplorer 0.90 final Link winPenPack Aggiornamento dalla versione 0.80 alla 0.90 final Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: niente da segnalare [ Edited Fri 03 Apr 2009 - 23:31 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | CubicExplorer 0.94 Link winPenPack Aggiornamento dalla versione 0.90 alla 0.94 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: niente da segnalare | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | CubicExplorer 0.95 Link winPenPack Aggiornamento dalla versione 0.94 alla 0.95 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: Testato con "Windows 7 Starter" Cartella aggiunta:1 ---------------------------------- C:\Users\R\AppData\Roaming\CubicExplorer File aggiunto:3 ---------------------------------- C:\Users\R\AppData\Roaming\CubicExplorer\layout.xml C:\Users\R\AppData\Roaming\CubicExplorer\sessions.xml C:\Users\R\AppData\Roaming\CubicExplorer\settings.xml [ Edited Sun 21 Aug 2011 - 09:16 ] | ||
| zandet2 |
![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3144 ![]() | E' possibile rendere nuovamente portabile l'applicazione modificando il file settings.path, sostituendo %APPDATA%\CubicExplorer\ con '.\' prima di eseguire il programma; in questo modo i settaggi verranno salvati nella cartella del programma e non in AppData. Scheda download aggiornata con le nuove caratteristiche. | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | CubicExplorer 0.95.1 Link winPenPack Aggiornamento dalla versione 0.95 alla 0.95.1 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: niente da segnalare | ||
