Aggiornamento: SumatraPDFGo to page << >> |
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Sumatra PDF 0.8.1 Link winPenPack Aggiornamento dalla versione 0.8 alla 0.8.1 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: Chiave aggiunta:2 ---------------------------------- HKLM\SOFTWARE\Microsoft\ESENT\Process\SumatraPDF HKLM\SOFTWARE\Microsoft\ESENT\Process\SumatraPDF\DEBUG | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Sumatra PDF 0.9 Link winPenPack Aggiornamento dalla versione 0.8.1 alla 0.9 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Sumatra PDF 0.9.1 Link winPenPack Aggiornamento dalla versione 0.9 alla 0.9.1 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Sumatra PDF 0.9.2 Link winPenPack Aggiornamento dalla versione 0.9.1 alla 0.9.2 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Sumatra PDF 0.9.3 Link winPenPack Aggiornamento dalla versione 0.9.2 alla 0.9.3 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-SumatraPDF 0.9.4 Link winPenPack Aggiornamento dalla versione 0.9.3 alla 0.9.4 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: Chiave aggiunta:1 ---------------------------------- HKLM\SOFTWARE\Classes\.pdf [ Edited Mon 20 Jul 2009 - 15:02 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Rcs wrote ... X-SumatraPDF 0.9.4 In questa versione sembra sparita la parte relativa all'associazione file, ed inoltre (vedere parte bassa della finestra): ![]() Se così fosse, a parte la richiesta di aggiornamenti all'avvio, il programma sembra già portatile. >> TEST RICHIESTO << | ||
| Ketty |
![]() ![]() Registered Member #5089 Joined: Sat 09 Jun 2007 - 02:27Posts: 1461 | Effettuato un test: nel registro non ho rilevato nulla, nemmeno questa
L'aggiornamento viene richiesto solo al primo avvio, deselezionandolo e cambiando drive, il programma mantiene le impostazioni salvandole nel file sumatrapdfprefs.dat | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Confermo, tutto ok! - - - Edit - - -
[ Edited Sat 01 Aug 2009 - 00:31 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-SumatraPDF 1.0 Link winPenPack Aggiornamento dalla versione 0.9.4 alla 1.0 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: Chiave aggiunta:3 ---------------------------------- HKLM\SOFTWARE\Classes\.pdf HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Acrobat.exe HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\AcroRd32.exe [ Edited Tue 17 Nov 2009 - 19:55 ] | ||
