![]() Go to page << >> |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | SumatraPDF 2.3 Link winPenPack Aggiornamento dalla versione 2.2.1 alla 2.3 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | SumatraPDF 2.3.2 Link winPenPack Aggiornamento dalla versione 2.3 alla 2.3.2 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | SumatraPDF 2.4 Link winPenPack Aggiornamento dalla versione 2.3.2 alla 2.4 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | SumatraPDF 2.5 Link winPenPack Aggiornamento dalla versione 2.4 alla 2.5 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | SumatraPDF 2.5.1 Link winPenPack Aggiornamento dalla versione 2.5 alla 2.5.1 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | SumatraPDF 2.5.2 Link winPenPack Aggiornamento dalla versione 2.5.1 alla 2.5.2 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare | ||
rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 922 ![]() | SumatraPDF 3.0.0 Link winPenPack -Link- ![]() Aggiornamento dalla versione 2.5.2 alla 3.0.0 Home: -Link- ![]() Direct link: -Link- ![]() What's new: -Link- ![]() | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | SumatraPDF 3.1.1 Link winPenPack Aggiornamento dalla versione 3.0.0 alla 3.1.1 Home: -Link- ![]() Direct link 32bit: -Link- ![]() Direct link 64bit: -Link- ![]() Risultato test: niente da segnalare ---Edit by Taf--- aggiunto link per il DL della versione portabile a 64 bit [ Edited Mon 23 Nov 2015 - 08:20 ] | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | SumatraPDF 3.1.2 Link winPenPack Aggiornamento dalla versione 3.1.1 alla 3.1.2 Home: -Link- ![]() Direct link 32bit: -Link- ![]() Direct link 64bit: -Link- ![]() | ||
eagleman |
![]() ![]() Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 2127 ![]() | SumatraPDF 3.2 Link winPenPack Aggiornamento dalla versione 3.1.2 alla 3.2 Home: -Link- ![]() Direct link 32bit: -Link- ![]() Direct link 64bit: -Link- ![]() Avvertenza: da questa versione è cessato il supporto a Windows XP. Chi volesse una versione compatibile con quel sistema operativo deve usare la 3.1.2 [edit by Taf - sistemata formattazione post e nuovi link di DL] [ Edited Mon 23 Mar 2020 - 11:37 ] | ||
