![]() Go to page >> |
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | X-Mule [rev5]
Ini n°1 [Player per le anteprime: Media Player Classic]
Ini n°2 [Player per le anteprime: MPlayer + MPUI]
Ini n°3 [Player per le anteprime: VideoLAN]
[ Edited Wed 22 Aug 2007 - 03:26 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | X-Mule Launcher [rev6]
INI:
[ Edited Wed 22 Aug 2007 - 03:58 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | X-Mule Launcher [rev7]
INI:
[ Edited Tue 04 Sep 2007 - 16:38 ] | ||
ozzolo |
![]() ![]() ![]() Registered Member #708 Joined: Wed 24 Jan 2007 - 09:35Posts: 26 | Andando un po' a naso ho personalizzato le cartelle, e inserito più (3) cartelle in Sharing.. sembra funzionare: ;---------------------------------------------------- ; ** Default ** ;--------------------------------------------------- eMuleHome=$Home$\$AppName$ ;eMule_Incoming=$Download$\$AppName$\Incoming ;eMule_Temp=$Download$\$AppName$\Temp eMule_Backup=$Backup$\$AppName$ ;eMuleShare=$Download$\$AppName$\Share ;--------------------------------------------------- ;---------------------------------------------------- ; ** Custom ** ;--------------------------------------------------- eMule_Incoming=E:\File Scaricati (* i percorsi assoluti sono deprecabili *) eMule_Temp=F:\FilesTemporanei met e part (* i percorsi assoluti sono deprecabili *) eMuleShare1 =G:\Share1 (* i percorsi assoluti sono deprecabili *) eMuleShare2 =H:\Share2 (* i percorsi assoluti sono deprecabili *) eMuleShare3 =I:\Share3 (* i percorsi assoluti sono deprecabili *) ;--------------------------------------------------- .. [WriteToFile=$ExeDir$\config\shareddir.dat] Line1=%eMuleShare1% Line2=%eMuleShare2% Line3=%eMuleShare3% [ Edited Sat 24 Nov 2007 - 14:42 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | ozzolo, hai inserito percorsi assoluti. In questo modo si perde il principio della portabilità a meno di intervenire ogni volta nell'ini. | ||
ozzolo |
![]() ![]() ![]() Registered Member #708 Joined: Wed 24 Jan 2007 - 09:35Posts: 26 | Sisi, quella è una scelta personale derivata dal fatto che uso wPP su hd su una partizione ad hoc e quindi i download li ridireziono... ..ma volevo solo indicare la possibilità di mettere più cartelle in sharing ![]() | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | [rev10]
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | [rev11] Modificata la gestione delle categorie. Predisposta la localizzazione di Italiano e Inglese.
Rivenmyst |
![]() ![]() Registered Member #1445 Joined: Sun 28 Jan 2007 - 16:19Posts: 86 | Nel file ini del launcher c'è scritto:
[Environment]
Il percorso di VLC è C:\X-mule\Bin\VideoLAN\X-VideoLAN.exe quindi dovrebbe essere cambiato in:
[Environment]
![]() ![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | Rivenmyst, questo forse è il risultato di qualche tua operazione "manuale"... Secondo la struttura prevista, X-Mule e X-Videolan dovrebbero essere posizionati allo stesso livello, non uno incapsulato nell'altro: winPenPack ...\Bin .......\eMule ...........emule.exe .......\VideoLAN ............videolan.exe ...\User .......\eMule .......\VideoLAN ...\XDrive .......X-Mule.exe .......X-Mule.ini .......X-Videolan.exe .......X-Videolan.ini Da quello che vedo tu invece hai posizionato X-VideoLan dentro la cartella dell'eseguibile di X-Mule (C:\X-Mule), mentre per farlo funzionare correttamente devi posizionarlo allo stesso livello, cioè in C:\ (C:\X-VideoLan). Ciao [ Edited Fri 23 May 2008 - 16:31 ] | ||
