AVS Disc Creator |
Bourne |
Registered Member #4287 Joined: Fri 20 Apr 2007 - 16:55Posts: 571 | Nome del software: AVS DISC CREATOR Versione: 2.1 Direct Link al download: -Link- Dimensione File: 5,7 MB (5889183 byte) Licenza: Freeware Nome autore: Online Media Technologies Ltd. Sito Web Autore: -Link- eMail autore: -eMail- (General information) - -eMail- (Technical support) Forum/Blog: -Link- Support/FAQ: -Link- (online help) - -Link- (faq) Descrizione: - BLU-RAY DISCS RECORDING SUPPORT Burn your data on the next-generation Blu-ray Discs and take full advantage of the new high-capacity storage technology (25 or 50 GB per Blu-ray Disc). With free AVS Disc Creator it is as easy as common CDs or DVDs. - WIDE RANGE OF SUPPORTED MEDIA TYPES AVS Disc Creator supports CD-R/RW, DVD+/-R, DVD+/-RW, DVD-RAM, Double/Dual Layer DVD and the latest Blu-ray technology BD-R and BD-RE. - WIDE RANGE OF SUPPORTED CD/DVD DRIVES Designed and tested for IDE, SATA, SCSI, USB, and Firewire drives. Works easily with most CD/DVD recording drives. - TRUE MULTISESSION SUPPORT Import previous session and add new files to an existing session - even for DVD formats. It does not matter what software you used to create this disc before. - EASY FILE/FOLDER MANAGEMENT Easily add, delete, replace, rename, and copy files and directories on CDs and DVDs. Write files or folders with right-click and selecting the Send To option. - DISC IMAGE SUPPORT Create, write and even edit disc images (ISO), remove or add files and folders from/to images. - PROJECTS Organize your burning tasks into projects to simplify everyday work. - MULTILINGUAL SUPPORT Now AVS Disc Creator interface is available in English, French, German, Spanish and Italian. - DATA VERIFICATION Verify your recorded discs to make sure no data is lost. | ||
Ketty |
Registered Member #5089 Joined: Sat 09 Jun 2007 - 02:27Posts: 1461 | Nome del software: AVS DVD Copy (è differente da quello riportato da Bourne) Aggiornamento Versione: 3.1.1.233 Direct Link al download: -Link- Cmq non è portabile C:\Documents and Settings\All Users\Dati applicazioni\AVS4YOU con sottocartelle e file e anche la licenza pare non essere più freeware Licenza per AVSMedia Software: Ogni licenza acquistata permette di installare ed utilizzare AVSMedia Software su un singolo computer. Ogni licenza può essere disattivata su un computer e riattivata su un altro computer. Allegato a questo Online Media Technologies Ltd. si riserva il diritto di applicare una tariffa speciale per gli aggiornamenti dei AVSMedia Software. | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | Visto il cambio di licenza e i dati lasciati sul pc, sposto in "software non portabilizzabili" Grazie per la segnalazione. | ||
