![]() Go to page >> |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Foobar2000 0.9.4.4 Link WinPenPack Aggiornamento dalla versione 0.9.4.3 alla 0.9.4.4 Home: -Link- ![]() Direct Link: -Link- ![]() [ Edited Tue 21 Aug 2007 - 16:20 ] | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Foobar2000 0.9.4.5 Link WinPenPack Aggiornamento dalla versione 0.9.4.4 alla 0.9.4.5 Home: -Link- ![]() Direct Link: -Link- ![]() | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Foobar2000 0.9.5 Link WinPenPack Aggiornamento dalla versione 0.9.4.5 alla 0.9.5 Home: -Link- ![]() Direct Link: -Link- ![]() | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Foobar2000 0.9.5.1 Link WinPenPack Aggiornamento dalla versione 0.9.5 alla 0.9.5.1 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato Test: Seguire le istruzioni - Portable tips how-to [ Edited Sun 24 Feb 2008 - 17:35 ] | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Foobar2000 0.9.5.2 Link WinPenPack Aggiornamento dalla versione 0.9.5.1 alla 0.9.5.2 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato Test: Non testato | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Foobar2000 0.9.5.3 Link WinPenPack Aggiornamento dalla versione 0.9.5.2 alla 0.9.5.3 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato Test: niente da segnalare Note per gli utenti: Seguire le istruzioni Portable tips how-to | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Foobar2000 0.9.5.4 Link WinPenPack Aggiornamento dalla versione 0.9.5.3 alla 0.9.5.4 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato Test: niente da segnalare Note per gli utenti: Seguire le istruzioni Portable tips how-to [ Edited Sun 06 Jul 2008 - 17:36 ] | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Foobar2000 0.9.5.5 Link WinPenPack Aggiornamento dalla versione 0.9.5.4 alla 0.9.5.5 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato Test: niente da segnalare Note per gli utenti: Seguire le istruzioni Portable tips how-to [ Edited Wed 06 Aug 2008 - 15:54 ] | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Foobar2000 0.9.5.6 Link WinPenPack Aggiornamento dalla versione 0.9.5.5 alla 0.9.5.6 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato Test: niente da segnalare Note per gli utenti: Seguire le istruzioni Portable tips how-to [ Edited Tue 23 Sep 2008 - 15:16 ] | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Foobar2000 0.9.6 Link WinPenPack Aggiornamento dalla versione 0.9.5.6 alla 0.9.6 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato Test: niente da segnalare Portable tips how-to: scaricare il file foobar2000_X.X.X.exe e lanciare il setup. In fase di installazione scegliere l'opzione "Portable installation" ed estrarre i file in una cartella a piacere. Per avviare il programma, lanciare il file foobar2000.exe [ Edited Sat 29 Nov 2008 - 16:38 ] | ||
