Aggiornamento: X-VirtualDub Go to page << >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-VirtualDub v1.8.2 (stable) Link winPenPack aggiornamento dalla versione 1.8.1 (stable) alla 1.8.2 (stable) Home: -Link- Direct Link: not portable -Link- [ Edited Sun 31 Aug 2008 - 08:12 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-VirtualDub v1.8.3 (stable) Link winPenPack aggiornamento dalla versione 1.8.2 (stable) alla 1.8.3 (stable) Home: -Link- Direct Link: not portable -Link- [ Edited Sun 31 Aug 2008 - 08:12 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-VirtualDub v1.8.4 (stable) Link winPenPack aggiornamento dalla versione 1.8.3 (stable) alla 1.8.4 (stable) Home: -Link- Direct Link: not portable -Link- [ Edited Sun 31 Aug 2008 - 08:12 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-VirtualDub v1.8.5 (stable) Link winPenPack aggiornamento dalla versione 1.8.4 (stable) alla 1.8.5 (stable) Home: -Link- Direct Link: not portable -Link- [ Edited Sun 31 Aug 2008 - 08:14 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-VirtualDub v1.8.6 (stable) Link winPenPack aggiornamento dalla versione 1.8.5 (stable) alla 1.8.6 (stable) Home: -Link- Direct Link: not portable -Link- [ Edited Mon 27 Oct 2008 - 15:09 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-VirtualDub v1.8.7 (stable) Link winPenPack aggiornamento dalla versione 1.8.6 (stable) alla 1.8.7 (stable) Home: -Link- Direct Link: not portable -Link- [ Edited Sun 28 Dec 2008 - 21:11 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-VirtualDub v1.8.8 (stable) Link winPenPack aggiornamento dalla versione 1.8.7 (stable) alla 1.8.8 (stable) Home: -Link- Direct Link: not portable -Link- ==EDIT zandet2== software wpp aggiornato [ Edited Mon 05 Jan 2009 - 23:36 ] | ||
Rivenmyst |
Registered Member #1445 Joined: Sun 28 Jan 2007 - 16:19Posts: 86 | Come mai è stato usato il launcher con file ini alla rev1, visto che è stato creato in data posteriore a quella della creazione dell'X-Launcher 1.3 [rev2]? [ Edited Thu 08 Jan 2009 - 14:48 ] | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | @Rivenmyst, la numerazione della revisione riguarda l'ini, se questo non viene modificato la numerazione rimane invariata, anche cambiando la versione del launcher. Se ci fai caso nella scheda riportiamo tre informazioni: versione software, versione launcher, versione ini, e ognuna può variare a seconda delle modifiche in modo indipendente dalle altre. Spero di essere stato esauriente. | ||
Rivenmyst |
Registered Member #1445 Joined: Sun 28 Jan 2007 - 16:19Posts: 86 | Ah, ok, ho confuso le cose. | ||
