[Word Processor] QJot 5.7 |
uroari |
Utente registrato #5744 Registrato il: gio 16 ago 2007 - 21:16Messaggi: 144 | Nome del software: QJot 5.7 Direct Link al download: -Link- Dimensione File: 984064 B (961 KB) Nome autore: Kenny Heimbuch (big thanks JediVcl) eMail autore: -eMail- Sito Web Autore: -Link- Descrizione: Mini Word. La sua principale peculiarità infatti è quella di poter leggere e modificare il formato DOC. Features: Opens and Saves .doc files; Insert images and objects; Insert file into text; Auto-saves user settings; Set paragraph/line spacing; Word Count; Stay Topmost; 100-level Undo/Redo; Auto-URL Detect; Close on ESC key; Drag Drop; Recent Documents; Block Indent/Unindent; Save selected text to file; Page Setup; Integration with WordWeb. Info originali: QJot is a relatively small, completely USB portable, alternative rich text editor that saves .doc files, inserts images and more. It is basically meant to serve as a good WordPad replacement. It supports Unicode and runs under Windows 2000 and Windows XP. Its native format is RTF, but it can open, edit and save Word and WordPerfect files (though not with all of their features). It can be used with any script that is supported by Windows and for which a font and a keyboard driver are installed, including right-to-left scripts. QJot is a relatively small alternative rich text editor that saves .doc files, inserts images and more. It is basically meant to serve as a good WordPad replacement. It supports Unicode and runs under Windows 2000 and Windows XP. Its native format is RTF, but it can open, edit and save Word and WordPerfect files (though not with all of their features). It can be used with any script that is supported by Windows and for which a font and a keyboard driver are installed, including right-to-left scripts. QJot can run from a floppy as well. Portable tips how-to: Estrarre con Universal Extractor, rinominare a piacere la cartella "{app}" e cancellare tutto il resto. Versione: 5.7 Lingua: Inglese Licenza: Freeware | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | Carino. Aggiunto al database.. | ||
deep |
Utente registrato #7 Registrato il: sab 20 gen 2007 - 20:57Messaggi: 568 | E' ottimo. Pratico e leggerissimo. L'unica pecca (per quanto mi riguarda non da poco) è che non gestisce le tabelle. | ||
