[Utilities] TimeTracker 4.4.0 |
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | Nome del software: TimeTracker 4.4.0 Direct Link al download: -Link- ![]() Dimensione File: (552960 b) 540 Kb Nome autore: Roland Bennett eMail autore: Sito Web Autore: -Link- ![]() Descrizione: programmino che effettua un monitoraggio dell'attività del computer. Particolarmente utile per avere informazioni sulle attività svolte al pc ad una determinata ora. Portable tips how-to: Già portatile. Una volta scompattato salva le impostazioni nel file TimeTracker.ini e i tracks in file con estensione .cvs all'interno della propria cartella. Versione: 4.4.0 Licenza: GNU General Public License Screenshot: ![]() Info originali: TimeTracker (TT) is a PC activity monitor for Windows. Ever spent the day in front of your PC, only to wonder at 5pm what you did that day? TT will tell you. TT will sit in your system tray and check every second which window is currently active on your desktop. The active window is the one you are currently typing or clicking in, and should be an accurate estimate of what you are working on. TT captures the window caption from the title bar and tracks the active time for that window. TT also allows the traditional feature of manual timers, you may enter your own task name and either double click (or use Space or Enter) to start/stop the task timer. The main aim of TT is though to be a time tracking tool that requires very little little user intervention. Who wants to do the boring work of timesheets? Rules allow TT to be able to tell which window activity belongs to which user task. Rules can be one or more partial window captions or file names, when any one of these conditions are met TT will start the task timer. When the conditions cease, TT will stop the task timer. The window and task active times can be saved to CSV (comma separated value) files. TT was designed to use very little computer resources, especially when running minimized. TT does not need to be installed, simply run the exe file. The main functions of TT are available in a popup menu, right click anywhere in the window or on the system tray icon to display the popup menu. [ Modificato mar 23 ott 2007 - 11:54 ] | ||
