X-Gimp 2.4.0 [rev4] - some problems and fixes |
| JackL |
![]() ![]() Utente registrato #6127 Registrato il: mar 18 set 2007 - 16:36Messaggi: 68 | Hi, I would like to share with some issues I encountered with the newest x-gimp program: 1) under brushes there is only clipboard selection unil you click "open the brush selection dialog" button (with painter) and then "refresh brushes" button (with cirkled arrows) 2) somehow, fu-scripts originally conteined in X-Gimp_2[1].4.0_rev4\Bin\Gimp\share\gimp\2.0\scripts directory, are only partially visible in menu under filters/alpha to logo - but even there it is inactive ... unless you click "xtns" menu in main window and there in "script-fu" you click "refresh scripts" option - this activate fu scripts in alpha to logo menu. What is interesting, programm recognize properly externally added scripts - as in user folder (in gimp/scripts file) as added to the main Bin\Gimp\share\gimp\2.0\scripts folder. 3) For those using liquid plugin - it wont work applied according creators guideline - you have to put exe file directly in User\Gimp\plug-ins file - then work fine Does anybody know how to fix point 1 and 2 permamently? I hope my short review will help a little for other gimp enthusiasts please share your experience as well best regards JackL | ||
| JackL |
![]() ![]() Utente registrato #6127 Registrato il: mar 18 set 2007 - 16:36Messaggi: 68 | ...I forgot to mention that paterns appeared as well only after refreshing as point no.1 above | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | JackL did you tray the normal-install version? The problem is not present? It is a bug of portable (X) version... I Think.... ![]() | ||
| JackL |
![]() ![]() Utente registrato #6127 Registrato il: mar 18 set 2007 - 16:36Messaggi: 68 | frankly speaking, it was aloooong loooong time I installed anything in regular way :]]]] ...so the answear is - I don't know cheers Danix | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | JackL ha scritto ... frankly speaking, it was aloooong loooong time I installed anything in regular way :]]]] Point 1 Ok, now I think it's ok... I think.... Replace X-Gimp.ini and X-Gimp.exe (please let me now if ALL problems are fixed). x-gimp_fix.zipJackL ha scritto ... 2) somehow, fu-scripts originally conteined in X-Gimp_2[1].4.0_rev4\Bin\Gimp\share\gimp\2.0\scripts directory, are only partially visible in menu under filters/alpha to logo - but even there it is inactive ... unless you click "xtns" menu in main window and there in "script-fu" you click "refresh scripts" option - this activate fu scripts in alpha to logo menu. What is interesting, programm recognize properly externally added scripts - as in user folder (in gimp/scripts file) as added to the main Bin\Gimp\share\gimp\2.0\scripts folder. For the point 2 read this: -Link- ![]() Redesigned menus The user interface has been redesigned, especially the top and context menus. There is now a seperate menu for colors, and the ScriptFu and PythonFu menu are no longer available. All filters and plugins can now be found in the Filters menu. For instance: Script-Fu -> Shadows -> Drop Shadow is now located at Filters -> Light and Shadow -> Drop Shadow. This is much more intuitive. [ Modificato ven 26 ott 2007 - 00:49 ] | ||
| JackL |
![]() ![]() Utente registrato #6127 Registrato il: mar 18 set 2007 - 16:36Messaggi: 68 | Hi, Danix- respect - all work fine now - I have to compare Ini files what has changed - perhaps one day I will be able to provide solution myself :] What have you changed in exe file ... and how? as for script fu - U R absolutely right except one part - perhaps it's only my experience but still to activate scripts in menu under filters/alpha to logo - you have to click "xtns" menu in main window and there in "script-fu" you have to click "refresh scripts" option. thanks a lot anyway for other fixes KUDOs JackL | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | JackL ha scritto ... What have you changed in exe file ... and how? From:
[FileToRun]
To:
[FileToRun]
Why? Because: -Link- ![]() JackL ha scritto ... perhaps it's only my experience but still to activate scripts in menu under filters/alpha to logo - you have to click "xtns" menu in main window and there in "script-fu" you have to click "refresh scripts" option. Sorry but if it is a bug, is a bug of Gimp. The normal-install Gimp version works in the same way and have the same "problem"... | ||
