Gimp 2.4.2 |
| JackL |
![]() ![]() Utente registrato #6127 Registrato il: mar 18 set 2007 - 16:36Messaggi: 68 | Hi, new version with multiple annoying bugs fixing appeared on line :] best regards J | ||
![]() ![]() ![]() Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 ![]() | Hi JackL, thank you for your signaling, but, for the future, I invite you to post in the right thread (is just for maintain ordered and cataloged the posts). Sorry, I forget to said it also in last days... This message has just moved in the right thread. Thank you for your collaboration... Best Regards ZioZione | ||
| JackL |
![]() ![]() Utente registrato #6127 Registrato il: mar 18 set 2007 - 16:36Messaggi: 68 | Off course - Perhaps I just focussed on english support forum too much cheers | ||
![]() ![]() ![]() Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 ![]() | Hi JackL, don't worry, is absolutely normal in Italian Forum (and there are A LOT of discussions more than English one...). I am sure that, in the future (as in the past... ), you will follow forum rules.. at the contrary of much Italian users... Best Regards ZioZione | ||
Gimp 2.4.2
