[Utility USB] USB Disk Ejector [Open Source]
icemax
mer 09 gen 2008 - 10:35
Utente registrato #194
Nome Software:USB Disk Ejector
Dimensione File: 487 KB (499,200)
Nome autore: Bgbennyboy
eMail autore: ..
Descrizione: USB Disk Ejector è un’utility gratuita che permette di rimuovere le periferiche
Usb connesse al sistema con un semplice doppio-click. Molto precisa nello scegliere la periferica
da rimuovere rispetto all'utility di windows. Supporta inoltre la linea di comando (vedi info originali)
Portable tips how-to: applicazione totalmente Portatile
Versione:1.1
Licenza:Open Source
Sorgenti disponibili per DELPHI 2007 qui : Download Source of USB Disk Ejector
screenshot :
info originali :
Current Version: 1.1
A program that allows you to quickly remove USB devices in Windows. It was originally designed to remove only USB pen drives but will now eject any USB device. It can be run as a non-visual command line program or a normal gui program. Its very useful if you have a USB flash/pen drive, especially if you use a menu such as Pstart or the Portable Apps launcher.
The command line options are very flexible, they can be used to:
• Eject the drive that the program is running from.
• Eject a drive by specifying a drive letter.
• Eject a drive by specifying a drive name.
• Eject a drive by specifying a partial drive name.
When run as a ‘normal’ GUI program the tools enables USB devices to be quickly ejected through a mouse click or keyboard press. It’s especially useful when dealing with multiple USB devices and for Vista users who don’t want the ‘now safe to remove this device’ dialog box to appear.
The program has been tested on WindowsXP and Windows Vista but should also work on older versions of Windows.
source page for application by Bgbennyboy here
mer 09 gen 2008 - 12:00
Ottimo!
Se non è possibile integrarlo nel menù sarà inserito di serie in tutti i winPenPack
Informazioni precise sulla licenza?
[ Modificato mer 09 gen 2008 - 12:03 ]
mer 09 gen 2008 - 12:22
Ciao Danix,
no, perché? Il programma può essere utilizzato anche dal pendrive da sconnettere
e si può mettere nel menu eseguendolo all'uscita.
Non ho ancora provato, ma secondo te, perché non dovrebbe funzionare?
mer 09 gen 2008 - 12:24
Ciao Danix,
che succede? Ti ho risposto ad un post che non dovrebbe ancora esserci, quindi risulto prima... e, credo, anche con questo post...
Problemi all'orologio del server?
El Salvador
mer 09 gen 2008 - 12:27
Utente registrato #301
Registrato il: lun 22 gen 2007 - 12:58
ha scritto ...
Infatti non ci sono (o almeno non le ho trovate) e mi sembra che un software senza licenza, vada automaticamente sotto copyright, quindi non open source.
mer 09 gen 2008 - 12:29
ZioZione, non è che hai risposto su un altro topic?
mer 09 gen 2008 - 12:30
Non capisco che succede!!!
Come mai i post vanno prima dell'ultimo?
mer 09 gen 2008 - 12:31
Si forse è l'orologio del server.....
mer 09 gen 2008 - 13:00
Ripensandoci.... ho detto una bella scemenza...
Come si fa a disattivare la periferica se il programma è nel menù, che quindi non può essere chiuso, né tantomeno disattivato?
Mi sembra del tutto inutile... USB Disk Ejector deve stare sul pc
MAXPC72
mer 09 gen 2008 - 13:07
Utente registrato #4454
Registrato il: lun 30 apr 2007 - 16:35
io finora ho usato questo:
USBDeview -Link-
lo ho messo nel menu', quando chiudo il wpp mi parte l'applicazione e disconnetto la penna, poi spengo il pc.
pero' in effetti uso il wpp su pc...
[ Modificato mer 09 gen 2008 - 13:09 ]
