[Utility]UDPixel 2.2 (controllo pixel bruciati)
icemax
mar 11 mar 2008 - 10:43
Utente registrato #194
Nome Software:UDPixel
Dimensione File: 156 KB (159,744)
Nome autore: Samuel Larché
eMail autore: -eMail-
Descrizione: Permette di controllare l'eventuale presenza dei
"famosi" pixel bruciati negli schermi LCD.
Portable tips how-to: Software NO-Install - scrive le proprie impostazioni sul
file : udpixel.xml che verrà creato nella cartella contenitore.
(* necessaria la presenza del .NET Framework v2)
Versione:2.2
Licenza:Freeware
Download - Pocket PC version smartUDPixel v0.2 English (.exe - 11kB)
screenshot :
info originali :
Description:
This program helps to locate and fix LCD screens dead pixels.
You can fix the stuck pixels by calling them to do rapid changes. You need to run this program for a couple of hours. There is no warranty on the result, but you don't really have anything to lose trying it out. Good luck.
Version: 2.2
Licence: Freeware
Platform: Windows Vista/XP/2000 with .NET Framework v2
Author: Samuel Larché
[ Modificato mar 11 mar 2008 - 10:45 ]
