[GRAFICA] IcoFX 1.5 - freeware Vai a pagina >> |
icemax |
Utente registrato #194 Registrato il: dom 21 gen 2007 - 22:27Messaggi: 1371 | Nome del software: IcoFX Pagina download: -Link- Dimensione File: 2,44 MB (2.562.683 byte) [ decompresso con UE] Nome autore: nd eMail autore: -nd Sito Web Autore: -Link- Descrizione: IcoFx free icon editor per Windows XP e Windows Vista. IcoFx include moltissimi tools ed effetti per l'editing e la manipolazione di icone. IcoFx crea, importa esporta trasforma qualsiasi tipo di icone , e mostra una bellissima e funzionale interfaccia. Portable tips how-to: versione portatile da scaricare dalla pagina di download Versione: Version 1.5 Licenza: Freeware Screenshots: info originali : Features of IcoFX Support for Vista icons with PNG compression Create icons for Windows 98 / ME / 2000 / XP / Vista Support for alpha channel New: Batch processing More than 40 effects, including Drop Shadow Create custom filters New: Multiple language support (Available translations: Catalan, English, German, Hungarian, Japanese, Romanian and Spanish) Resolutions up to 256x256 Data types: 2, 16, 256, True Color, True Color + Alpha Extract icons (including Vista icons) from 32 bit exe and dll Import / export images (transparency also) Many useful drawing tools like brush, line, rectangle and more Transparent, Brighten/Darken, Blur/Sharpen tools for retouching Create icon from an image with a single click Adjust the contrast, brightness, hue, saturation, transparency and color balance of icons Change the dimension of images New: Images can be faded using the fadeout dialog Increase / decrease the opacity of an image New: Easy shadow handling RGB and HSB color modes New: History of recently opened files New: Window menu for easy window switching Possibility to store favorite colors Capture image from the desktop Grid for precision work New: Side bar for easy image switching New: File Explorer window for easy import New: Full drag and drop support Sizable preview window Multiple undo Blur the edge of the brush Rotate the image at any angle [Scheda aggiornata] [ Modificato lun 09 lug 2007 - 01:42 ] | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | Scusa Icemax, ma la cartella in Dati Applicazioni a cui hai dato l'1% di responsabilità, ne merita almeno il 99%, dato che contiene le impostazioni del programma. Quindi, a meno di chiedere un'autorizzazione all'autore per la portatilizzazione, NON E' PORTATILE. | ||
icemax |
Utente registrato #194 Registrato il: dom 21 gen 2007 - 22:27Messaggi: 1371 | ho inviato una email riguardo al launcher , per portabilizzarlo attendo risposte [ Modificato sab 02 giu 2007 - 10:21 ] | ||
icemax |
Utente registrato #194 Registrato il: dom 21 gen 2007 - 22:27Messaggi: 1371 | a tempo record : VERSIONE PORTATILE Email originale : Hello, Thank you for your interest in my software. IcoFX has already a portable version, so there is no need for this workaround. This portable version stores all its settings in its installation folder. You can download IcoFX Portable Edition from -Link- Best regards, Attila Kovrig quindi il link modificato per la versione portatile : -Link- o più esattamente il link - al file (ZIP) : -Link- e ... - alla lingua : Italian v1.2 - Translation by Giacomo Margarito -Link- Italiano v1.2 - Alternative translation by Pispolino -Link- all'Help file : Italiano v1.0 - Translation by Pispolino -Link- una info per Danix : errore in upload del file : [ecco il log] Caricato 'IcoFX.rar' Caricato 'error.jpg' Il file eccede i limiti massimi consentiti. Eliminato. [dimensione del software pack : 1,28 MB pensaci tu .. fratello ciaus .. e_state contenti [ Modificato sab 02 giu 2007 - 12:40 ] | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | Il programma è interessante. Ma lo hai testato per vedere se è portatile? Molti autori pubblicizzano versioni portatili dei loro programmi (vedi deepburner) che di portatile hanno solo il nome.. Chiedigli l'autorizzazione all'inserimento nei wPPs Hai inviato l'eMail concordata, vero? E poi, per piacere, inseriscilo in Upload. Grazie. [ Modificato sab 02 giu 2007 - 12:41 ] | ||
icemax |
Utente registrato #194 Registrato il: dom 21 gen 2007 - 22:27Messaggi: 1371 | Danix ha scritto ... Il programma è interessante. Ma lo hai testato per vedere se è portatile? Molti autori pubblicizzano versioni portatili dei loro programmi (vedi deepburner) che di portatile hanno solo il nome.. Chiedigli l'autorizzazione all'inserimento nei wPPs Hai inviato l'eMail concordata, vero? E poi, per piacere, inseriscilo in Upload. Grazie. ehm..... This portable version stores all its settings in its installation folder. esattamente crea [All'interno del programma ] una cartella IcoFX con all'interno il file di configurazione : config.cfg config.cfg example :
MainForm]
va bene così .... ..o continuo .... fratello ... sto aspettando l'email per l'autorizzazione all'inserimento nel pack in riferimento all'upload del file : una info per Danix : errore in upload del file : [ecco il log] Caricato 'IcoFX.rar' Caricato 'error.jpg' Il file eccede i limiti massimi consentiti. Eliminato. [dimensione del software pack : 1,28 MB pensaci tu .. fratello [ Modificato sab 02 giu 2007 - 12:52 ] | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | File remoto icemax, non reale. Dato che, come ben sappiamo, le licenze non permettono di hostare files non GPL. Leggi qui, se ancora non l'hai fatto -Link- Non ci penso io. Grazie. [ Modificato sab 02 giu 2007 - 12:56 ] | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | Il link al download non è più valido. Icemax,puoi chiedere all'autore se il link all'edizione portatile è stato rimosso, o se era solo per winPenpack? E in questo caso come dobbiamo comportarci (dato che io non me lo ritrovo.... ) | ||
eagleman |
Utente registrato #9 Registrato il: sab 20 gen 2007 - 21:36Provenienza: Veglie Messaggi: 1706 | Questo è il link alla versione portatile A quanto mi risulta, funziona. Rettifico, funziona, ma solo se ci si collega dal sito ufficiale. Non sono premessi link diretti da siti esterni. Al massimo, fate un bel copia e incolla deel'indirizzo nell barra del browser e funziona. [ Modificato sab 09 giu 2007 - 15:42 ] | ||
eagleman |
Utente registrato #9 Registrato il: sab 20 gen 2007 - 21:36Provenienza: Veglie Messaggi: 1706 | Aggiornato alla versione 1.6. Al contrario della precedente, questa è DEL TUTTO portatile. Da questa versione in poi (si spera), la traduzione italiana è a cura di Massimo Pizzolante Leuzzi (traduttore, tra gli altri, di ISTool, il wizard per la creazione dei setup con InnoSetup, e GetRight). -Link- [ Modificato sab 12 apr 2008 - 21:33 ] | ||
