Programming Language |
Peter G |
Utente registrato #5718 Registrato il: mar 14 ago 2007 - 21:38Messaggi: 21 | I would like to suggest: X-Python (--> -Link- and X-Ruby (www.ruby-lang.org) Both powerful and (more or less !?) easy-to-learn programming languages. It would be great to use that languages without the need of (hard) install an the PC | ||
Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 | Hi Peter G, thank you for your suggestions! At this moment we don'have such environments, but did you already seen 1) Portable Python -Link- 2) AllInOneRuby -Link- ? You are welcome to check if they fit your needs. Best Regards ZioZione [ Modificato mer 02 apr 2008 - 12:25 ] | ||
