[Test richiesto] X-Gnucash |
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | X-Gnucash Download: -Link- ![]() Licenza: GNU General Public License Motivazioni
[ Modificato mer 07 mag 2008 - 12:34 ] | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | [Fixed] TEST RICHIESTO Aggiungere le seguenti stringhe a X-Gnucash.ini
[StringReplace=%HOME%\.gconf\apps\gnucash\history\%gconf.xml]
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | Altro bug: Online Banking non funziona correttamente. Dimenticanza nell'ini (parte modificata): [WriteToReg=%REG_DIR%\Aqbanking.reg] MainKey=HKEY_LOCAL_MACHINE\SOFTWARE\Aqbanking Paths|"providerdir"=$Bin$\$AppName$\lib\aqbanking\plugins\16\providers|\\" Paths|"bankinfodir"=$Bin$\$AppName$\lib\aqbanking\plugins\16\bankinfo|\\" Paths|"importerdir"=$Bin$\$AppName$\lib\aqbanking\plugins\16\imexporters|\\" Paths|"wizarddir"=$Bin$\$AppName$\lib\aqbanking\plugins\16\wizards|\\" Paths|"pkgdatadir"=$Bin$\$AppName$\share\aqbanking|\\" Paths|"sysconfdir"=$Bin$\$AppName$\etc|\\" Paths|"localedir"=$Bin$\$AppName$\share\locale|\\" Paths|"xmldatadir"=$Bin$\$AppName$\share\aqhbci\xml|\\" Paths|"cfgmoduledir"=$Bin$\$AppName$\lib\\aqbanking\plugins\16\frontends\qbanking\cfgmodules|\\" [WriteToReg=%REG_DIR%\Gwenhywfar.reg] MainKey=HKEY_LOCAL_MACHINE\SOFTWARE\Gwenhywfar Paths|"prefix"=$Bin$\$AppName$|\\" Paths|"libdir"=$Bin$\$AppName$\lib|\\" Paths|"plugindir$Bin$\$AppName$\lib\gwenhywfar\plugins\38|\\" Paths|"sysconfdir"="$Bin$\$AppName$\etc|\\" Paths|"localedir"=$Bin$\$AppName$\share\locale|\\" [WriteToReg=%REG_DIR%\GnuCash.reg] MainKey=HKEY_LOCAL_MACHINE\SOFTWARE\GnuCash "InstallationDirectory"=$Bin$\$AppName$|\\" Paths|"prefix"=$Bin$\$AppName$|\\" Paths|"libdir"=$Bin$\$AppName$\lib|\\" Paths|"pkglibdir"=$Bin$\$AppName$\lib\gnucash|\\" Paths|"sysconfdir"=$Bin$\$AppName$\etc|\\" Paths|"localedir"=$Bin$\$AppName$\share\locale|\\" [RunBefore] RegEdit=%REG_DIR%\Aqbanking.reg;Gwenhywfar.reg;GnuCash.reg
![]() ![]() ![]() Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 ![]() | Ciao Danix, per rispondere al nostro amico riguardo alla presunta non portatilità di X-GnuCash, ho anche approfittato per scaricarlo e testare la parte riguardante il tuo fix: tutto ok. Già che ci siamo, avrei trovato anche un'altra cosa: sotto determinate condizioni (dovrebbe accadere quando fai File|Open) viene creata questa cartella C:\Documents and Settings\nomeutente\Application Data\gtk-2.0 relativa al fatto che per quella operazione si utilizza il dialog di GTK. Se riesci a sistemare anche questa, saremmo proprio a posto (il log di Regshot è pulitissimo). Cordialmente ZioZione | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | Grazie mille, ZioZione Hai ragione e in più c'è anche il file .recently-used.xbel.
Allego la REV4: x-gnucash.zip | ||
