Modifiche e aggiornamenti software da winPenPack 3.4 Vai a pagina << >> |
Jesurun |
Utente registrato #6054 Registrato il: mer 12 set 2007 - 16:35Messaggi: 1 | It would be great if the pack could have a packer if someone wants to use one of the x-programs localy in a PC. Something like a "x-software local installer", that can create a folder with the selected x-software (with its actual user settings) for use it in a PC without the need of insert the flash drive. It would be very helpfull. Thanks. Joe | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | Welcome to winPenPack, Jesurun. Please post your request in a correct section of forum (i.e. English support or another one of italian forum). This thread is reserved only to update submissions for wpp_3.5 (next release). Thank you P.S. I'll delete the last two post. | ||
Utente registrato #675 Registrato il: mar 23 gen 2007 - 23:49Provenienza: Salvitelle (Sa) Messaggi: 12717 | X-Miranda 0.7.7 Link winPenPack Aggiornamento dalla versione 0.7.6 alla 0.7.7 Home: -Link- Direct Link: (non portatile) (Windows NT, 2000, XP, Vista only) -Link- Direct Link: (non portatile) (Windows 95, 98, ME) -Link- [ Modificato mar 03 giu 2008 - 22:25 ] | ||
Utente registrato #675 Registrato il: mar 23 gen 2007 - 23:49Provenienza: Salvitelle (Sa) Messaggi: 12717 | X-FreeMind 0.9.0 Beta18 (unstable) Link winPenpack Aggiornamento dalla versione 0.9.0 Beta17 (unstable) alla 0.9.0 Beta18 (unstable) Home: -Link- Direct Link: (not portable) -Link- [ Modificato mer 04 giu 2008 - 22:28 ] | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | (nuovo inserimento wpp_1gb/wpp_essential) JPEGView 1.0.17 -Link- | ||
Utente registrato #675 Registrato il: mar 23 gen 2007 - 23:49Provenienza: Salvitelle (Sa) Messaggi: 12717 | X-Synthesia 0.6.4 Aggiornamento dalla versione 0.6.3 alla 0.6.4 Home: -Link- Direct link: -Link- [ Modificato dom 08 giu 2008 - 10:27 ] | ||
Utente registrato #675 Registrato il: mar 23 gen 2007 - 23:49Provenienza: Salvitelle (Sa) Messaggi: 12717 | X-xpy 0.10.3 Link winPenPack Aggiornamento dalla versione 0.10.2 alla 0.10.3 Home: -Link- Direct Link: -Link- [ Modificato dom 08 giu 2008 - 20:55 ] | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | (nuovo inserimento wpp_school_3.5 | nuovo inserimento in wpp_1gb_3.5 e conseguente eliminazione di X-GraphCalc) SpeedCrunch 0.10.1 -Link- | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | (eliminazione da wpp_school) X-Synthesia 0.6.3 -Link- dalla versione 0.6.2 non viene più rilasciato sotto MIT License, ma sotto licenza Freeware. | ||
Utente registrato #675 Registrato il: mar 23 gen 2007 - 23:49Provenienza: Salvitelle (Sa) Messaggi: 12717 | MediaCoder 0.6.1.4115 Link winPenPack Aggiornamento dalla versione 0.6.1.4112 alla 0.6.1.4115 Home: -Link- Direct Link: -Link- Risultato Test: Non testato | ||
