Opera Browser |
jlajla |
Utente registrato #11035 Registrato il: sab 10 mag 2008 - 02:31Messaggi: 38 | Sorry about the Off Topic entry so I have added a thread for people who would otherwise miss this. Opera has the best malware immunity going at the moment since Firefox has become a target. I have been using X-Opera since the false positive virus problem in Operausb. Even though it wasn't a virus if virus software quarantines it and kills your program it should be fixed, particularly since the fix is just to upx the operausb exe file. X-Opera is better anyway except that any widgets used are not portable. I have been looking at the problem but have found no solution yet. The X-Opera launcher looks to be doing everything right so the answer is eluding me. An amazingly fast response from Danix follows. Now widgets are portable Add this code to X-Opera.ini [StringReplace=$ExeDir$\profile\widgets\widgets.dat] "preserve">|widgets=$ExeDir$\profile\ | ||
jlajla |
Utente registrato #11035 Registrato il: sab 10 mag 2008 - 02:31Messaggi: 38 | The spellcheck modification for aspell does not work with Opera 9.5 beta 2, not that it should necessarily, I just wanted to let you know. | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | Did you try with the 9.27 version? The spellcheck with aspell works? | ||
jlajla |
Utente registrato #11035 Registrato il: sab 10 mag 2008 - 02:31Messaggi: 38 | Yes, it works great. I posted that in the Opera Virus thread but I should put it here also since it is more on topic. | ||
jlajla |
Utente registrato #11035 Registrato il: sab 10 mag 2008 - 02:31Messaggi: 38 | Changing line 107 in X-Opera.ini preserves the skin. Old line: Button Set|\skin==$ExeDir$ New line: Button Set|\skin==$ExeDir$\profile\ | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | Yes, this happens when you download and set other skins, because they go to the profile folder. But if you select one of default skins (included in X-Opera\Bin\Opera\skin)? Which is the best option to set? | ||
jlajla |
Utente registrato #11035 Registrato il: sab 10 mag 2008 - 02:31Messaggi: 38 | If the skin folder in profile is empty or missing it drops to the default skin. Not a perfect solution but it allows for a bit of customization. | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | I think this solution is valid for both options:
[ Modificato dom 03 ago 2008 - 11:50 ] | ||
