The Coccinella |
Peter G |
Utente registrato #5718 Registrato il: mar 14 ago 2007 - 21:38Messaggi: 21 | I have found an interesting Instant Messaging Application "The Coccinella", to be found here: -Link- (//coccinella.im) It's under GNU GPL and is designed for Jabber and including a "whiteboard". Maybe it's possible to bring that into a X-Package ? | ||
Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 | Peter G ha scritto ... Maybe it's possible to bring that into a X-Package ? Mmmmmhhhhh let me see..... [ Modificato lun 11 ago 2008 - 15:29 ] | ||
Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 | AAAARRRRGGGGHHHH It's a nightmare!!!! Lots of registry voices (HKLM\classes, HKCU\Software\Microsoft), files in Appdata\Microsoft etc... Anyway, try this launcher: x-coccinella_beta.zip How to: unpack the X-Coccinella_beta.zip and put the "Coccinella Messenger-0.96.8.exe" binary (from the website) on the "X-Coccinella\Bin" folder. Attention, there is a bug: the launcher cannot export the "HKLM\Software\Classes\im" voice, maybe because the name is shorter than 3 char... Please, test it if you can, possibly using regshot... Thank you Cheers [ Modificato lun 11 ago 2008 - 21:01 ] | ||
justsky |
Utente registrato #12361 Registrato il: mer 16 lug 2008 - 06:19Messaggi: 28 | I just want to say that it is wonderful that you are working with this app. An open source somewhat universal IM with whiteboard that conferences and works well with slow connections. Great addition. | ||
Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 | Hi justsky, this is only a "first and rough" attempt to create a portable version of Coccinella, needing tests and revision... Cheers | ||
Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 | New beta launcher : bug Fix for registry exportations. x-coccinella_beta_2.zip As described before, put the Coccinella binary on the "\Bin\Coccinella" folder. Test needed, as usual..... Bye | ||
