JackL |
![]() ![]() Utente registrato #6127 Registrato il: mar 18 set 2007 - 16:36Messaggi: 68 | Hi - and what you think about Iron browser? - It has a lot of nice features - webkit engine, separated tabs (sandbox technic) private mode, and is fixed with all google indificiency - all google spyconnection is cut :] ... if only bound some day with proxy - that would be prety discrete and safe thing cheers JackL EDIT BY ZioZione: it is always better to add a link regarding the signaled software... Thank you for your support! -Link- ![]() [ Modificato ven 03 ott 2008 - 08:42 ] | ||
![]() ![]() ![]() ![]() Utente registrato #251 Registrato il: lun 22 gen 2007 - 10:12Provenienza: Buttrio (UD) Messaggi: 3368 ![]() | Hi JackL, also for Chrome and/or is too early to consider for a "stable" version. These softwares are pretty good, and they are growing up quite quickly, but is better to wait for a more stable and bogfixed version. In any case "Iron" is certainly better than "Google Chrome" in terms of security and privacy. We will wait for a fixed release and than we will see. Thank You for Your suggestion. PS: You can already find a first portable version of chrome here: -Link- ![]() | ||
JackL |
![]() ![]() Utente registrato #6127 Registrato il: mar 18 set 2007 - 16:36Messaggi: 68 | nice link though! in the time of google translator it's not a problem to use german/italian/...even polish sites :] thanks | ||
