Chrome or better Iron
JackL
gio 02 ott 2008 - 17:56
Utente registrato #6127
Registrato il: mar 18 set 2007 - 16:36
Hi - and what you think about Iron browser? - It has a lot of nice features - webkit engine, separated tabs (sandbox technic) private mode, and is fixed with all google indificiency - all google spyconnection is cut :] ... if only bound some day with proxy - that would be prety discrete and safe thing
cheers
JackL
EDIT BY ZioZione: it is always better to add a link regarding the signaled software... Thank you for your support! -Link-
[ Modificato ven 03 ott 2008 - 08:42 ]
ven 03 ott 2008 - 08:49
Hi JackL,
also for Chrome and/or is too early to consider for a "stable" version.
These softwares are pretty good, and they are growing up quite quickly, but is better to wait for a more stable and bogfixed version.
In any case "Iron" is certainly better than "Google Chrome" in terms of security and privacy.
We will wait for a fixed release and than we will see.
Thank You for Your suggestion.
PS: You can already find a first portable version of chrome here:
JackL
ven 03 ott 2008 - 13:13
nice link though! in the time of google translator it's not a problem to use german/italian/...even polish sites :]
thanks
