[Utility dll] Dll Export Finder |
Moticanus |
Utente registrato #4618 Registrato il: gio 10 mag 2007 - 08:29Provenienza: Modica Messaggi: 1352 | Nome del software: Dll Export Finder Direct Link al download: -Link- Dimensione File: 195 kb Nome autore: Jacquelin Potier eMail autore: n/a Sito Web Autore: -Link- Descrizione: V. info originali Info originali: Dll Export Finder finds functions exported by dll in a specified directory. This is the tool you need if you don't remember in which dll is located the exported function your looking for. The searched string can use the '*' and '?' jokers, and an insensitive case search is done. To list all exported functions in a diretory, just make a search on '*' Portable tips how-to: Estrarre il file dllexportfinder_bin.zip e avviare l'eseguibile dllexportfinde.exe. Versione: 1.0 (09.09.2008) Licenza: GPL Note sulla portabilità: con regshot ho trovato solo: Valore aggiunto:2 ---------------------------------- HKU\S-1-5-21-1417001333-842925246-854245398-1004\Software\Microsoft\Windows\CurrentVersion\Explorer\Browse For Folder Width: 0x0000013E HKU\S-1-5-21-1417001333-842925246-854245398-1004\Software\Microsoft\Windows\CurrentVersion\Explorer\Browse For Folder Height: 0x00000120 | ||
