[Internet] X-Winscp |
bagr |
Utente registrato #4759 Registrato il: sab 19 mag 2007 - 09:25Messaggi: 15 | Software name: X-Winscp (original WinSCP) Direct Link to download: -Link- Author's name: Martin Přikryl Author's Website: -Link- Description:WinSCP is an open source free SFTP client and FTP client for Windows. Legacy SCP protocol is also supported. Its main function is safe copying of files between a local and a remote computer. Version: X-Winscp 0.1 alpha (winscp 4.0 beta) License: GNU v.2 Screenshot: [ Modificato dom 20 mag 2007 - 09:27 ] | ||
simongr |
Utente registrato #23 Registrato il: sab 20 gen 2007 - 23:54Messaggi: 858 | Good idea, but if you take off all you sites maybe it will be better next time By the way, I try to connect to my site trhough FTP and x-winSCP gaves me a generic connection (but with x-filezilla it works fine)... So i ask to other forum people to try your alpha release. Maybe it can be an error of my machine but i can't try with another one... But I appreciate your work, I used winSCP with some clients of mine and i find it useful and light. So keep on! Thank You! [ Modificato sab 19 mag 2007 - 15:44 ] | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | Thank you bagr for you suggestion And welcome to winPenpack. But... why did you not use the ini file that the program natively creates in $ExeDir$ folder? And your x-version create a file called "PUTTY.RND" in %APPDATA% Try this version: I added the settings backup function too.. ... perhaps X-Winscp final
Download: 1179588809_1_FT3687_x-winscp_4.0_beta.zip [ Modificato sab 19 mag 2007 - 17:46 ] | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | Added automatic configuration for Putty directory:
New program release: 1179593904_1_FT3687_x-winscp_4.0_beta.zip [ Modificato sab 19 mag 2007 - 19:02 ] | ||
