[Pending] X-Emu48_1.47_rev2_test_1 Vai a pagina << |
mpscuba68 |
Utente registrato #27703 Registrato il: lun 25 mag 2009 - 19:12Provenienza: Norway/Thailand Messaggi: 10 | Software name: Emu48 1.48 Direct Link to download: -Link- File size: 513 kb Author name: Sebastien Carlier and Christoph Giesselink Author eMail: -eMail- Author website: -Link- Description: The HP48 Emulator Emu48 was originally created by Sebastien Carlier and is published under the GPL. The latest version of Emu48 can emulate a HP38G, HP39G, HP40G, HP48SX, HP48GX and a HP49G. Description from software website. Version: 1.48 License: GNU General Public License Screenshot: Portable version by Magne Petkovic/winPenPackTeam. Version: 1.48_revision 1 Description: The best mathematical HP Emulator as a HP48GX. Now portable and editable for personal use. Portable tips how-to: Administrative priveleges are needed for correct program execution. Additional templates and ROM files can be found at -Link- Emu48 need ROM images to work. Because of license reasons ROM's aren't included, but they can be downloaded on several other sites. Revision R ROM dump of the HP 48GX calculator. HP graciously began allowing this to be downloaded in mid-2000. Direct download link: -Link- Size: 323 kb. Put the file in the Emu48 BIN folder. Version: 1.48 revision 1 License: GNU General Public License Download: -Link- File size: 1.10 MB MD5sum: 878c0903c5b4f51503d9292fb0ee30ea Screenshot: Did I do it right this time? Can we do it like this? [ Modificato dom 09 ago 2009 - 04:52 ] | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | Probably it is difficult to understand what mean some fields of INI file. However, I thought it was clear from our X-Software Development guidelines. When you write Ini Rev.Author=Magne Petkovic, this means that you have written a revision or some part of INI code for make portable or to improve the (portable) program. Have you made this? [ Modificato mar 16 giu 2009 - 21:52 ] | ||
mpscuba68 |
Utente registrato #27703 Registrato il: lun 25 mag 2009 - 19:12Provenienza: Norway/Thailand Messaggi: 10 | Yes sir, I have. | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | Compared to the first launcher attached by ZioZione -Link- and the rev 2 posted successively -Link- , You have added your name and a new splash screen. This is not properly a revision. Therefore, when we'll decide to put X-Emu48 in download, if we'll do, we will be happy to thank you for the signalling. | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | Many thanks to Magne Petkovic for helping us to make the HP48 Emulator portable version. Thanks also for signalling and software description: -Link- X-Emu48_1.47_rev2_test_1 (1,3 MB) Warning: "Emu48 need ROM images to work. Because of license reasons ROM's aren't included, but they can be downloaded on several other sites." ------------ Please note: a new version (1.48) of HP48 Emulator has been released -Link- , but it seems the scripts can not be executed (test needed). Nota: è stata rilasciata una nuova versione (1.48) di HP48 Emulator -Link- , ma sembra che gli script non possano essere eseguiti (test richiesto). [ Modificato lun 21 feb 2011 - 10:24 ] | ||
mpscuba68 |
Utente registrato #27703 Registrato il: lun 25 mag 2009 - 19:12Provenienza: Norway/Thailand Messaggi: 10 | Ok. Try this version, actually, all that is different is the emu48.exe file!!! ---[TEMPORARY REMOVED FOR LICENSE REASONS ]--- [ Modificato ven 31 lug 2009 - 13:13 ] | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | From author website: "Emu48 need ROM images to work. Because of license reasons ROM's aren't included, but they can be downloaded on several other sites." Mine is the original package. Yours, instead, contains ROM.48G that is not open source. For this reason the original package doesn't work. If it is not possible to find open source ROM images, all packages of this thread have to be removed and unfortunately we can not release X-Emu48. [ Modificato ven 31 lug 2009 - 13:20 ] | ||
mpscuba68 |
Utente registrato #27703 Registrato il: lun 25 mag 2009 - 19:12Provenienza: Norway/Thailand Messaggi: 10 | Software name: Emu48 1.48 Direct Link to download: -Link- File size: 513 kb Author name: Sebastien Carlier and Christoph Giesselink Author eMail: -eMail- Author website: -Link- Description: The HP48 Emulator Emu48 was originally created by Sebastien Carlier and is published under the GPL. The latest version of Emu48 can emulate a HP38G, HP39G, HP40G, HP48SX, HP48GX and a HP49G. Description from software website. Version: 1.48 License: GNU General Public License Screenshot: Portable version by Magne Petkovic/winPenPackTeam. Version: 1.48_revision 1 Description: The best mathematical HP Emulator as a HP48GX. Now portable and editable for personal use. Portable tips how-to: Administrative priveleges are needed for correct program execution. Additional templates and ROM files can be found at -Link- Emu48 need ROM images to work. Because of license reasons ROM's aren't included, but they can be downloaded on several other sites. Revision R ROM dump of the HP 48GX calculator. HP graciously began allowing this to be downloaded in mid-2000. Direct download link: -Link- Size: 323 kb. Put the file in the Emu48 BIN folder. Version: 1.48 revision 1 License: GNU General Public License Download: -Link- File size: 1.10 MB MD5sum: 878c0903c5b4f51503d9292fb0ee30ea Screenshot: Did I do it right this time? Can we do it like this? | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | Without ROM.48G it doesn't work. Where you have downloaded ROM.48G? [ Modificato mar 11 ago 2009 - 15:35 ] | ||
mpscuba68 |
Utente registrato #27703 Registrato il: lun 25 mag 2009 - 19:12Provenienza: Norway/Thailand Messaggi: 10 | !!!http://www.hpcalc.org/hp48/pc/emulators/gxrom-r.zip!!!! That's if you get it right also my download link in my previus post. And that's from !!!www.hpcalc.org!!! directly. Revision R ROM dump of the HP 48GX calculator. HP graciously began allowing this to be downloaded in mid-2000. And also please: If I made any misstakes this time, notify me, so I can correct them. Remember: I am a novice, not an expert like the rest of you. | ||
Vai a pagina <<
