X-Mozilla programs - extension problem |
bagr |
Utente registrato #4759 Registrato il: sab 19 mag 2007 - 09:25Messaggi: 15 | Affected all versions which have enabled talkback extension X-Firefox X-Thunderbird X-Sunbird Tested on (OS: Windows XP): X-Thunderbird 1.5.0.12 [English] X-Sunbird [0.5 Rc1 - En] Problem: All three programs have an extension called talkback if this (by default is on) extension is on it makes folder Talkback in C:\Documents and Settings\*\Application Data\ and sub folders for each of those programs. In those sub folders some *.ini and other files are saved. To solve this problem you have to turn extension off or uninstall it or make some change in X-*.ini file. [ Modificato dom 03 giu 2007 - 14:49 ] | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | Thank you. I'll test it. | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | I have not C:\Documents and Settings\*\Application Data\ and sub folders directories when I start the programs... Are you sure that is the correct path? | ||
bagr |
Utente registrato #4759 Registrato il: sab 19 mag 2007 - 09:25Messaggi: 15 | I download X-Thunderbird 1.5.0.12_en.zip unpack it run X-Thunderbird then I close app. And there is C:\Documents and Settings\user\Application Data\Talkback\MozillaOrg\Thunderbird15\ ... I tested on two PC and on both the folder was created. Can anyone else confirm/test this ? | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | Hi bagr! I have the Talkback folder just when X-Sunbird starts and not X-FF and X-TB.. Fixes for X-Sunbird: Fixed Ita: -Link- Fixed En: -Link- | ||
Utente registrato #251 Registrato il: lun 22 gen 2007 - 10:12Provenienza: Buttrio (UD) Messaggi: 3358 | Same results as Danix here! Using Thunderbird 2.0.0.4 EN and ITA (not tested with 1.5!) I had the problem only with OLD X-Sunbird version. [ Modificato ven 20 lug 2007 - 08:47 ] | ||
