X-Firefox on Windows ME?
ryan14
dom 04 apr 2010 - 12:07
Utente registrato #38463
Registrato il: dom 04 apr 2010 - 12:00
Does X-Firefox 3.6.3 [rev14 English] work on Windows ME(Millenium)?:
Because Firefox does not work on Windows 98 and Windows ME.
lun 05 apr 2010 - 12:13
Utente registrato #9
Provenienza: Veglie
I don't think so, simply because X-firefox is the same browser that you can use on your pc, but slightly modified to run on an usb stick.
If the normal firefox can't run on win Me, the x version won't do it too.
mar 06 apr 2010 - 11:57
Hi ryan14, welcome here!
Eagleman was exhaustive enough! Last version of X-firefox and Firefox are exactly the same program (the "X" version is only to make it portable).
But, if You want a Firefox release running under win 98, please use 2.0.0.20
And You can find the portable version here:
[ Modificato mar 06 apr 2010 - 11:58 ]
